Hi everyone ,
I use 'epics 3.14.12.1 in linux' + asyn + stream + CSS. I controled the motor through serial. Now I want to change a pv through CSS and then send it to serial.
I mean these, For example:
I set speed value 2 in CSS. Then all command about moving motor should send the string contain the speed value to serial,like xxxx2
When I set speed value 3 in CSS, all command sent to serial should contain 3, like xxx3.
No need to change the xxx.proto file and make which is the way I use now , it is very inconvenient.
Could you introduce me a much better way. Thanks, Li X
| ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
