I am not sure I understand what you mean.
Can you send some specific examples of commands you send to change the speed, and then another command that must contain the speed?
From: [email protected] [[email protected]] on behalf of l123173 [[email protected]]
Sent: Tuesday, April 12, 2016 10:02 PM
To: [email protected]
Subject: the way pv sent to serial changed
Hi everyone ,
I use 'epics 3.14.12.1 in linux' + asyn + stream + CSS.
I controled the motor through serial. Now I want to change a pv through CSS and then send it to serial.
I mean these, For example:
I set speed value 2 in CSS. Then all command about moving motor should send the string contain the speed value to serial,like xxxx2
When I set speed value 3 in CSS, all command sent to serial should contain 3, like xxx3.
No need to change the xxx.proto file and make which is the way I use now , it is very inconvenient.
Could you introduce me a much better way.
Li X
- the way pv sent to serial changed l123173
RE: Re:RE: Re:RE: the way pv sent to serial changed Mark Rivers
<2016>
2025
2026
<2016>
2025
2026
