Hi Phil,
We do the same as Bruno mentions.
Data Height (ArraySize1_RBV)
Data Width (ArraySize0_RBV)
where the PVs are from the StdArray plugin.
In addition you’ll also need to have additional rules for setting the X and Y axis Min and Max values. These rules use the PVs from the detector driver that knows about binning and ROI selection:
X Axis Min - (MinX_RBV)
Y Axis Min - (MinY_RBV)
X Axis Max (MinX_RBV + ArraySizeX_RBV)
Y Axis Max (MinY_RBV + ArraySizeY_RBV)
We also use a another rule that defines the maximum intensity (the Maximum property) based on a PV. Then we have a Scaled Slider widget to change the intensity.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
> On Apr 20, 2016, at 9:26 AM, Bruno Martins <[email protected]> wrote:
> Hi Phil,
> You can create two rules, for the data_width and data_height properties, that look at the $(P)ArraySize0_RBV and $(P)ArraySize1_RBV PV's
> HTH,
> Bruno
> On Wed, Apr 20, 2016 at 6:44 AM, Phil Atkin <[email protected]> wrote:
> Thanks Gabriela,
> - but I guess my question was ambiguous. If I understand correctly, your script adjusts the height of the IntensityGraph widget so that its aspect ratio matches the image.
> But the IntensityGraph will not display anything at all unless I set its Data Height and Data Width properties to match the attached array. Do you have something to accomplish this?
> Also: I have no idea how to actually attach the code or make it run at an appropriate time. Can you point me at documentation that describes this?
> Thanks
> Phil
> On 20/04/2016 11:34, [email protected] wrote:
> this is the very simple python script that I use:
> from org.csstudio.opibuilder.scriptUtil import PVUtil
> imageWidget = display.getWidget('Image')
> imageXSizeWidget = display.getWidget('X-Size')
> imageYSizeWidget = display.getWidget('Y-Size')
> try :
> imageXSizePV = imageXSizeWidget.getPV()
> imageYSizePV = imageYSizeWidget.getPV()
> nImageRows = PVUtil.getLong(imageYSizePV)
> nImageColumns = PVUtil.getLong(imageXSizePV)
> imageWidget.setPropertyValue('graph_area_width', 512)
> imageWidget.setPropertyValue('graph_area_height', (512.0/nImageColumns)*nImageRows)
> except :
> pass
> Phil Atkin <[email protected]> ha scritto:
> Hi,
> I'm using BOY IntensityGraph to show a (stdArray) output image from an areaDetector driver/plugin.
> The size of my array changes quite a bit.
> Can someone tell me (in laborious detail if necessary, please) how to set up scripts or "embedded rules" on the IntensityGraph to cope with a variable-sized image?
> Thanks!
> Phil
- Re: Script BOY IntensityGraph to show areaDetector output of variable size Phil Atkin
- Re: Script BOY IntensityGraph to show areaDetector output of variable size gabriele . salvato
- Re: Script BOY IntensityGraph to show areaDetector output of variable size Bruno Martins
How to use registry to replace vxWorks symLib? Michael Westfall
<2016>
2025
2026
<2016>
2025
2026
