Hi Saeed,
all of the 343-1 communication modules should work fine with the s7nodave driver. Actually if you have a S7-300 CPU with DN/DP you don't even need such a communication module because you can communicate in the same way with the Ethernet ports of the CPU directly.
Jens
Von: [email protected] [mailto:[email protected]] Im Auftrag von saeed haghtalab
Gesendet: Dienstag, 26. April 2016 22:20
An: [email protected]
Betreff: Connection to Siemens S7 PLC
Hi all,
I'm new to EPICS and I want to integrate the S7-300 PLC into EPICS. I have read that it can be done by S7 driver via TCP/IP module. But there is some kinds of these modules like 343-1 Lean, 343-1, 343-Advanced. Is there any difference between these kinds of modules in operating with S7 driver? Does CP343-1 Lean work well with s7nodave?
Best regards,
S. Haghtalab
- Re: AW: Connection to Siemens S7 PLC Remi Faure
- Connection to Siemens S7 PLC saeed haghtalab
caget always not found l123173
Re: caget always not found Ralph Lange
<2016>
2025
2026
<2016>
2025
2026
