Hi Ralph, The email I sent to you be send back again and again, so I sent it here.
I have used the CA command sucefully in other computer, I puzzled why I
failed here. And I did not change the set up about ADDR_LIST and so on.I use the CA command on the same host as the IOC and the same computer. The pv name was typed rightly, it is the same as in "dbl". The whole command is "caget RPS1" and RPS1 is my pv name. Cheers, Li x At 2016-04-27 17:48:39, "Ralph Lange" <[email protected]> wrote:
| ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
