1. is it true that all the "process" functions of all the records within one IOC share ONE
thread? So we should avoid having within one IOC multiple records which have
extensive calculations (including memory copying) in their "process" functions?
Extensive calculations should not be done in the process function. That will slow down whatever thread that record is processing in. If a record (or device support) will do something time-consuming then record processing should be done in a 2 steps: the initial call to process() sets PACT and starts the time consuming operation in a separate thread. When the processing is complete the record is told to process again, and sets PACT back to 0.
From: [email protected] [[email protected]] on behalf of Ralph Lange [[email protected]]
Sent: Sunday, May 01, 2016 3:57 AM
To: EPICS Tech-Talk
Subject: Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields
Hi Dehong,
I'll try to get some of your questions answered.
No.
Allocation to threads in the IOC depends on the scan mechanism. Periodic scanning uses one thread for each of the scan periods, I/O Interrupt scanning and the completion phase of asynchronous record processing run from one of the generic callback threads (one per priority), PINI and CP input link related processing use a separate thread, Channel Access uses a thread per client, ...
When taking the proper locks, any thread on the IOC may process records.
2. the CA server uses another thread(s) with lower priority for broadcasting to "camonitor"s
and replying to "caget"s? Is this thread(s) shared by all the records?
Channel Access uses a pair of threads (one for each direction) per remote client.
3. does the CA server have its own buffers for each field/broadcasts? Or it shares the same
memory locations with the records?
Here the answer seems to be "yes" for scaler fields, BUT "no" for string or array fields
Correct.
Scalar fields are put in the per-client-queue as values, arrays and strings are put in the queue as pointers.
does this mean that there is NO guarantee that string/array fields will have the correct
time stamps?
Correct.
In the congestion case, i.e. when the array data in the record gets updated before an older event is posted, the CA server will send an update to the client that combines the old time stamp (taken from the queue) with the newer data (taken from the record).
Note: The EPICS V4 protocol, pvAccess, manages structured data and guarantees updates to be always consistent.
4. what happens when the CA server replies to "caget"? Do we also have this "scalers are
buffered, but string/arrays are not" issue? Or "nothing is buffered, but takes whatever
is available (old data and new time stamp, or new data and old time stamp etc) at that
particular moment?
The answers to "caget" use the same mechanism: scalars are always consistent, arrays/strings may have newer data under congestion.
5. for completeness, a real dumb question: if I don't, or haven't have time yet to, call "db_post_event",
the "camonitor"s will certainly not get anything, but can a "caget" still get the current value?
Yes. The difference is basically that in the context of record processing, the scanning thread calls process() which posts events for the fields that were changed, for "caget" it is the CA incoming thread that posts the event for the field that was being asked for.
Sorry for all these dumb questions. More and more we are using EPICS in a daq fashion.
>From the above document, I see a great danger in correctly assigning time stamps to
string/array data. Without patching EPICS base, it seems there is no lock/mutex will help
to close this hole. Hopefully it is me who missed something.
EPICS 3.15 adds mechanisms that allow things like putting copies of arrays/strings in the queue, helping with consistency.
EPICS 3.16/V4 supports structured data on the network, guarantees consistency, and is especially targeted at data acquisition applications.
Please consider switching to newer EPICS versions that provide the features you need rather than trying to add patches to a previous version.
If you find issues with the newer version, there will be a team of developers interested to improve the code. Patching 3.14, you will basically be on your own.
Best regards,
~Ralph
- Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
- RE: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Mooney, Tim M.
- Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Till Straumann
- Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
- Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Ralph Lange
Erratum: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Ralph Lange
<2016>
2025
2026
<2016>
2025
2026
