1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ?
To: lzfneu <[email protected]>
Date: Tue, 3 May 2016 12:52:26 +0000
> On May 3, 2016, at 3:58 AM, lzfneu <[email protected]> wrote:
> First, thanks for your respond, the problem have been solved !
Good.
> and also the alarm tree with PV name shows:
> PV:SXFEL:RP:Gamma:02:RealDose:alarm (UNDEFINED/No Connection, UNDEFINED/No Connection)
Check your channel access address list, by this line in the file that you pass via the -pluginCustomization command line argument:
org.csstudio.platform.libs.epics/addr_list=..
By default, it starts out looking only on the local host (https://github.com/ControlSystemStudio/cs-studio/blame/master/applications/alarm/alarm-plugins/org.csstudio.alarm.beast.server/plugin_customization.ini)
See http://www.aps.anl.gov/epics/docs/ca.php for general channel access documentation, and refer to the docbook chapter named "Hierarchical Preferences”, http://cs-studio.sourceforge.net/docbook/ch06.html, for more on the -pluginCustomization files.
> Below is my test.xml file in details which imitate "org.csstudio.alarm.beast.configtool/demo/demo.xml". By the way, what is the <latching>true<latching> mean?
To use the alarm system, you should read the docbook chapter named "Alarm System”, see http://cs-studio.sourceforge.net/docbook/ch14.html:
"Alarm System Behavior
The alarm system will typically _latch_ alarms. This means ..”
-Kay
Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? lzfneu
Re: Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? Kasemir, Kay
RE: Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? lzfneu
Prev: RE: Reg programming in EPICS environment for master slave control Mark Rivers
Next: Send JMSAlarm Messages from BOY Panel Jensen Zelaya
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? lzfneu
Next: Reg programming in EPICS environment for master slave control Himanshu Tyagi
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
