1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base 3.15.4-pre1 - URGENT call for beta testing
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 6 May 2016 17:55:14 +0200
One of two planned weeks have passed - and we've got two test reports so far (native Darwin and Windows 10).
That's good, but not good enough. Please contribute!
Cheers,
~Ralph
On 29/04/2016 17:26, Ralph Lange wrote:
Dear all,
The first pre-release candidate of the next "current" series release, EPICS Base 3.15.4-pre1, has been tagged and prepared for download. [1]
This time, we urgently need your help with beta testing.
The 3.15 feature "Allow IOC to bind to a subset of the existing network interfaces" required some noticeable changes in the Channel Access server on the IOC.
Starting with 3.15.4, these changes will apply to every single IOC, on every platform and every target architecture. This is a critical part of any EPICS system.
We thoroughly tested the changes on the main architectures: Linux, Windows, vxWorks and RTEMS. However, we don't have the necessary access, experience and time to check all other platforms. That's why we need your help.
The EPICSwiki contains a page with a test plan: https://wiki-ext.aps.anl.gov/epics/index.php/RSRV_Configuration_Test_Plan
Please download and build 3.15.4-pre1, fire up the test IOC, and run the 6 different tests described on the Wiki page. This will probably take less than an hour.
Report any findings as soon as possible, so that we can fix issues before 3.15.4 gets released.
The less common your target platform, the more important is your help.
Next step in the release process is release candidate 1, planned to be bundled and published on Friday the 13th. (Seriously: two weeks from now.)
Thanks a lot for your help!
~Ralph
[1] https://launchpad.net/epics-base/3.15/3.15.4
Base 3.15.4-pre1 - URGENT call for beta testing Ralph Lange
Prev: Re: Reg programming in EPICS environment for master slave control Michael Davidsaver
Next: antelope error in Windows 7 cygwin build of EPICS base 3.15.3 Ana Malagon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Base 3.15.4-pre1 - URGENT call for beta testing Ralph Lange
Next: deny ca_search response for a record? Paul Sichta
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
