Hi, I'm trying to build EPICS base 3.15.3 on cygwin, on a Windows 7 host and getting errors when trying to build this. I know there have been other threads about this on the forum, such as http://www.aps.anl.gov/epics/tech-talk/2015/msg01742.php make --version I get: $ make --version GNU Make 4.1 Built for x86_64-unknown-cygwin or g++ -o antelope.exe -m32 epicsTempFile.obj closure.obj error.obj lalr.obj lr0.obj antelope.obj mkpar.obj output.obj reader.obj skeleton.obj symtab.obj verbose.obj warshall.obj /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-pc-cygwin/5.3.0//libstdc++.dll.a when searching for -lstdc++ /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lstdc++ /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-pc-cygwin/5.3.0//libgcc_s.dll.a when searching for -lgcc_s /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-pc-cygwin/5.3.0//libgcc.a when searching for -lgcc /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lgcc /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lcygwin /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/w32api/libadvapi32.a when searching for -ladvapi32 /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -ladvapi32 /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/w32api/libshell32.a when searching for -lshell32 . . . /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lshell32 /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/w32api/libuser32.a when searching for -luser32 . . . /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -luser32 /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/w32api/libkernel32.a when searching for -lkernel32 . . . /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lkernel32 /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-pc-cygwin/5.3.0//libgcc_s.dll.a when searching for -lgcc_s . . . /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lgcc_s /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-pc-cygwin/5.3.0//libgcc.a when searching for -lgcc . . . /usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lgcc collect2: error: ld returned 1 exit status make[3]: *** No rule to make target 'antelope.exe', needed by '../../../bin/cygwin-x86/antelope.exe'. Stop. make[3]: Leaving directory '/cygdrive/c/Users/admx/epics/base/base-3.15.3/src/libCom/O.cygwin-x86' ../../configure/RULES_ARCHS:61: recipe for target 'install.cygwin-x86' failed make[2]: *** [install.cygwin-x86] Error 2 make[2]: Leaving directory '/cygdrive/c/Users/admx/epics/base/base-3.15.3/src/libCom' ../configure/RULES_DIRS:88: recipe for target 'libCom.install' failed make[1]: *** [libCom.install] Error 2 make[1]: Leaving directory '/cygdrive/c/Users/admx/epics/base/base-3.15.3/src' configure/RULES_DIRS:88: recipe for target 'src.install' failed make: *** [src.install] Error 2 . . .
| ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
