Hello, My name is Kyle, and I am working on an EPICS driver for an Agilent Technologies TwisTorr 304 Controller. Unfortunately, I have hit a bit of a roadblock in my protocol file, and I need a little nudge in the right direction. I am able to send the device commands and receive responses, but I am looking to automate the checksum process with some of the built in checksum converters. Could you please teach me how to use the converters and flags to ignore the first byte and compute the checksum of any given input and output? Below I have posted what I have written in my protocol file. I also wrote an explanation of how this device computes its checksum. The Checksum Calculation #The MESSAGE is a string with the following format: #<STX>+<ADDR>+<WIN>+<COM>+<DATA>+<ETX>+<CRC> #<CRC> = XOR of all characters subsequent to <STX> and including the <ETX> terminator. The value is hexadecimal coded and indicated by two ASCII character. # Example for Soft Start (ON) COMMAND # <0x02>|<0x80>|<0x31><0x30><0x30>|<0x31>|<0x31>|<0x03>|<0x42><0x32>| # STX | ADDR | WINDOW | WR | ON | ETX | CRC | # Response for Soft Start (ON) COMMAND # <0x02>|<0x80>|<0x06>|<0x03>|<0x38><0x35>| # STX | ADDR | ACK | ETX | CRC | The bytes for the checksum begin with ADDR and end with EXT (inclusive). The resulting checksum is B2 in hex. It is indicated by two separate ASCII characters. 'B' = 42 and '2' = 32. This is for the Soft Start (ON) command. The same logic would apply to the response. My Protocol File Terminator = ""; ExtraInput = Ignore; LockTimeout = 2000; ReplyTimeout = 100; WriteTimeout = 50; ReadTimeout = 50; #Requests and Answers #Command that turns on the soft start function softStartOn { out "\x02\x80\x31\x30\x30\x31\x31\x03\x42\x32"; in "%s"; } I would like to know how to use %<xor> properly in this command to calculate the checksum. My attempts are listed below: \x02\x80\x31\x30\x30\x31\x31\x03\%<xor> \x02\x80\x31\x30\x30\x31\x31\x03\%1.1<xor> \x02\x80\x31\x30\x30\x31\x31\x03\%2r<xor> \x02\x80\x31\x30\x30\x31\x31\x03\%2R<xor> \x02\x80\x31\x30\x30\x31\x31\x03\%xor \x02\x80\x31\x30\x30\x31\x31\x03\%1.12R<xor> \x02\x80\x31\x30\x30\x31\x31\x03\%2r%<xor>
| ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
