1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Model 8743 Closed-Loop Picomotor,Controller / Driver
To: "'Jemian, Pete R.'" <[email protected]>, "Siddons, David P." <[email protected]>, EPICS <[email protected]>
Date: Thu, 12 May 2016 21:45:41 +0000
The existing driver does support the 8743 closed-loop picomotor controller.  However, it does not support closed-loop mode.
It looks like it should be easy to implement.
You need to add this function:
asynStatus nf874xAxis::setClosedLoop(bool closedLoop)
  asynStatus status;
 sprintf(pC_->outString_, "%s MM %d", axisName_, closedLoop ? 0 : 1);
  status = pC_->writeController();
  return status;
You might also want to add controller-specific parameters to control these:
CL Closed loop update interval
DB Deadband
FE Following error
These would be implemented in the writeInt32 and writeFloat64 methods.
From: [email protected] [mailto:[email protected]] On Behalf Of Jemian, Pete R.
Sent: Thursday, May 12, 2016 3:32 PM
To: Siddons, David P.; EPICS
https://github.com/epics-modules/motor/blob/master/motorApp/NewFocusSrc/874xMotorDriver.cpp
Looks like that is a TODO item
Sent via the Samsung Galaxy Note® 4, an AT&T 4G LTE smartphone
-------- Original message --------
Date: 5/12/2016 4:28 PM (GMT-05:00)
To: EPICS <[email protected]>
Subject: Model 8743 Closed-Loop Picomotor,Controller / Driver
Hi Tech talkers,
    Does the motor record support the 8743 closed-loop Picomotor controller?
Pete.
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
Model 8743 Closed-Loop Picomotor,Controller / Driver D Peter Siddons
RE: Model 8743 Closed-Loop Picomotor,Controller / Driver Jemian, Pete R.
Prev: Re: generalTime time provider consternation Andrew Johnson
Next: Re: Recommendation on a PCIe ADC board Ford, Christopher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Model 8743 Closed-Loop Picomotor,Controller / Driver Jemian, Pete R.
Next: long string command to device Gofron, Kazimierz
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
