1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: long string command to device
Date: Fri, 13 May 2016 02:23:51 +0000
I am writing EPICS driver for Keithley 3706A, and am trying to figure out how to send long string commands to the 3706A.
The ICL commands have no short version, and some commands exceed current 40 char length limit of the stringout record.
____
The EPICS stringoutRecord.h is limited to 40 char.
char		val[40];	/* Current Value */
In my driver assigning to stringout:
"dmm.setconfig('1019:1020','fourwireohms')"
results in "dmm.setconfig('1019:1020','fourwireohms" being send - missing last 2 characters
Is there a replacement for stringout with relaxed limit?
Simplified command/respond test:
record(stringout, "$(P)$(Dmm)command") {
  field(FLNK, "$(P)$(Dmm)reply")
record(stringin, "$(P)$(Dmm)reply") {
  field(DTYP, "asynOctetWriteRead")
  field(INP, "@asyn($(PORT) 0) $(P)$(Dmm)command")
I am currently using this format in the driver:
record(stringout, "$(P)$(Dmm)dmm_read") {
  field(DTYP, "asyn so stringParm")
  field(FLNK, "$(P)$(Dmm)dmm_get_str.VAL  PP MS")
  field(VAL, "print(dmm.measure())")
  field(OUT, "@asyn($(PORT))TERM=0a")
record(stringin, "$(P)$(Dmm)dmm_get_str") {
  field(DTYP, "asyn si stringParm")
  field(INP, "@asyn($(PORT))TERM=0a,TO=10000")
  field(FLNK, "$(P)$(Dmm)read_finished.VAL  PP MS")
Kazimierz
RE: long string command to device Mark Rivers
AW: long string command to device Zimoch Dirk (PSI)
Prev: Re: Recommendation on a PCIe ADC board Ford, Christopher
Next: RE: long string command to device Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Model 8743 Closed-Loop Picomotor,Controller / Driver Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
