> I found in testAsynPortDriver.cpp file, there is a function like this:
> void simTask(void *drvPvt) ,but I can’t find where is called? what's the usage of this function?
That function is the background thread that runs the simulation. It is called from the constructor in this call:
/* Create the thread that computes the waveforms in the background */
status = (asynStatus)(epicsThreadCreate("testAsynPortDriverTask",
epicsThreadPriorityMedium,
epicsThreadGetStackSize(epicsThreadStackMedium),
(EPICSTHREADFUNC)::simTask,
this) == NULL);
> Another question, there is a parameter named as “Vert gain”, seems it’s used to convert volt’s unit to mv, am I right?
> thanks a lot for your help.
It is used to set the gain of the vertical signal, like setting what type of scope probe (1X, 10X, 100X) is used on a real scope. However, I just noticed that changing this value does not change the display until you then process the VoltsPerDivSelect PV. You can select the same VoltsPerDivSelect menu choice, then the display will change to reflect the current VertGainSelect.
From: [email protected] [[email protected]] on behalf of Silver [[email protected]]
Sent: Monday, May 16, 2016 10:16 PM
To: tech-talk
Subject: testAsynPortDriver questions
hi,
Best wishes
Geyang 2016-05-17
- testAsynPortDriver questions Silver
Call for contributions to talk on EPICS v4 White, Greg
<2016>
2025
2026
<2016>
2025
2026
