Hi everyone,
I have some error when I make base3.15.3 in Fedora 23.
I set the environment of EPICS_HOST_ARCH=linux-x86_64 and EPICS_BASE=/opt/epics/base, EPICS_EXTENSIONS=/opt/epics/extensions
Can you tell me the reason?
This is my information.
make[2]: Leaving directory '/opt/epics/base/src/libCom/RTEMS'
make -C libCom/test install
make[2]: Entering directory '/opt/epics/base/src/libCom/test'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
T_A=linux-x86_64 install
make[3]: Entering directory '/opt/epics/base/src/libCom/test/O.linux-x86_64'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/opt/epics/base/src/libCom/test/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/base/src/libCom/test'
make -C ca/client install
make[2]: Entering directory '/opt/epics/base/src/ca/client'
make[3]: Entering directory '/opt/epics/base/src/ca/client/O.linux-x86_64'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../src/ca/client/test -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -MM -MF searchTimer.d ../searchTimer.cpp
../searchTimer.cpp:151:0: Error:未终止的 #if
#if 0
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../src/ca/client/test -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -c ../searchTimer.cpp
#if 0
../searchTimer.cpp: 在成员函数‘virtual epicsTimerNotify::expireStatus searchTimer::expire(const epicsTime&)’中:
../searchTimer.cpp:150:33: Error:expected ‘}’ at end of input
if ( this->searchAttempts ) {
../searchTimer.cpp:150:33: Warning:在有返回值的函数中未发现 return 语句 [-Wreturn-type]
../../../../configure/RULES_BUILD:228: recipe for target 'searchTimer.o' failed
make[3]: *** [searchTimer.o] Error 1
make[3]: Leaving directory '/opt/epics/base/src/ca/client/O.linux-x86_64'
../../../configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/opt/epics/base/src/ca/client'
../configure/RULES_DIRS:88: recipe for target 'ca/client.install' failed
make[1]: *** [ca/client.install] Error 2
make[1]: Leaving directory '/opt/epics/base/src'
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Liang
- Re: error when make base3.15.3 Benjamin Franksen
How to disable sequencer output at startup? Touchard Dominique
NTP time provider and ticksPerSecond Michael Westfall
<2016>
2025
2026
Re: How to disable sequencer output at startup? Benjamin Franksen
<2016>
2025
2026
