Hi Liang
It would help if you could prefix the build command ("make") with
"LANGUAGE=C" (and then re-send the output), so we can see the error
messages in English.
Cheers
Ben
Am 17.05.2016 um 14:54 schrieb 梁雅翔:
> Hi everyone,
> I have some error when I make base3.15.3 in Fedora 23.
> I set the environment of EPICS_HOST_ARCH=linux-x86_64 and EPICS_BASE=/opt/epics/base, EPICS_EXTENSIONS=/opt/epics/extensions
> Can you tell me the reason?
> This is my information.
> make[2]: Leaving directory '/opt/epics/base/src/libCom/RTEMS'
> make -C libCom/test install
> make[2]: Entering directory '/opt/epics/base/src/libCom/test'
> make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
> T_A=linux-x86_64 install
> make[3]: Entering directory '/opt/epics/base/src/libCom/test/O.linux-x86_64'
> make[3]: Nothing to be done for 'install'.
> make[3]: Leaving directory '/opt/epics/base/src/libCom/test/O.linux-x86_64'
> make[2]: Leaving directory '/opt/epics/base/src/libCom/test'
> make -C ca/client install
> make[2]: Entering directory '/opt/epics/base/src/ca/client'
> make[3]: Entering directory '/opt/epics/base/src/ca/client/O.linux-x86_64'
> /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../src/ca/client/test -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -MM -MF searchTimer.d ../searchTimer.cpp
> ../searchTimer.cpp:151:0: Error:未终止的 #if
> #if 0
> /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../src/ca/client/test -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -c ../searchTimer.cpp
> #if 0
> ../searchTimer.cpp: 在成员函数‘virtual epicsTimerNotify::expireStatus searchTimer::expire(const epicsTime&)’中:
> ../searchTimer.cpp:150:33: Error:expected ‘}’ at end of input
> if ( this->searchAttempts ) {
> ../searchTimer.cpp:150:33: Warning:在有返回值的函数中未发现 return 语句 [-Wreturn-type]
> ../../../../configure/RULES_BUILD:228: recipe for target 'searchTimer.o' failed
> make[3]: *** [searchTimer.o] Error 1
> make[3]: Leaving directory '/opt/epics/base/src/ca/client/O.linux-x86_64'
> ../../../configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
> make[2]: *** [install.linux-x86_64] Error 2
> make[2]: Leaving directory '/opt/epics/base/src/ca/client'
> ../configure/RULES_DIRS:88: recipe for target 'ca/client.install' failed
> make[1]: *** [ca/client.install] Error 2
> make[1]: Leaving directory '/opt/epics/base/src'
> configure/RULES_DIRS:88: recipe for target 'src.install' failed
> make: *** [src.install] Error 2
> Thanks,
> Liang
"Make it so they have to reboot after every typo." ― Scott Adams
signature.asc
Description: OpenPGP digital signature
- Re: error when make base3.15.3 Benjamin Franksen
- error when make base3.15.3 梁雅翔
RE: How to disable sequencer output at startup? Zelazny, Michael Stanley
<2016>
2025
2026
<2016>
2025
2026
