1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ABS() in calc record
From: "Laznovsky Michael (PSI)" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 21 May 2016 10:43:54 +0000
Hello- to the keepers of the Sacred Source Code, in the course of developing some
displays I noticed that a PV which should never be < 0 had a persistent flickering minus
sign (-0.000)... the cause was traced to the implentation of ABS in the calc record, ie:
        case ABS_VAL:
            if (*ptop < 0.0) *ptop = - *ptop;
            break;
In my case, the CALC is "ABS(A*B)", and e.g. A=0 and B<0 results in ABS(-0), which does
not satisfy the if() in the code because -0 is NOT less than zero, so the sign is not flipped
back to positive.
Using fabs() instead fixes it (and probably also saves a branch).
cheers,
Mike
RE: ABS() in calc record Laznovsky Michael (PSI)
Re: ABS() in calc record Johnson, Andrew N.
Prev: RE: Build failed in Jenkins: epics-base-3.15-win32-test #58 M Santosh ADitya
Next: RE: ABS() in calc record Laznovsky Michael (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
