1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn: what if a driver wants to force callbacks?
Date: Wed, 25 May 2016 21:50:51 +0000
In 2015 there was some discussion on Tech-Talk about how to force a callback for a parameter that had not changed values.
Mark Rivers suggested a work-around, as shown below.
I wonder if anyone has an update on the situation since then?  Has any other method appeared?  Or did you have success with the work-around?
 -Chris Ford, SLAC
On16 Nov 2015 Mark Rivers writes:
> If a driver wants to force a callback there is a method that does not require any changes to the base classes, e.g. exposing statusChanged_ as protected or adding a new
> isMotorRecordnowFilterButAlwaysProcess_ flag.  The driver simply needs to set a parameter to a different value from present and then back to its current value, for example
>  setDoubleParam(pC_->motorPosition_(position+1.);
>  setDoubleParam(pC_->motorPosition_(position);
>  callParamCallbacks();
Re: asyn: what if a driver wants to force callbacks? Torsten Bögershausen
Area Detector question Jörn Wüstenfeld
RE: Area Detector question ulrik.pedersen
RE: Area Detector question Mark Rivers
Prev: Re: asyn build on cygwin fails Ana Malagon
Next: RE: asyn build on cygwin fails freddie.akeroyd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Area Detector question Mark Rivers
Next: Re: asyn: what if a driver wants to force callbacks? Torsten Bögershausen
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
