1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unable to tunnel CSS CA through ssh tunnels
To: Till Straumann <[email protected]>
Date: Tue, 31 May 2016 19:06:20 +0000
Till,
I've looked over your "caxy" package.  Nice job!
Also see http://www.delegate.org/delegate/, which is a very nice "Swiss
Army Knife" of tunnelling and port forwarding using SOCKS. It does both TCP
and UDP forwarding.  The documentation is a fair translation from Japanese,
so takes a little bit of work to understand.
Less versatile is https://github.com/apenwarr/sshuttle, which uses ssh
forwarding.
Unfortunately, I was hoping for a bundled solution, so I wouldn't have to put
our users through any more work than necessary.  It's to bad that CSS is not
ssh tunnelling compatible while EPICS base, and the clients that use it, are.
- Jon
On Sun, May 29, 2016 at 04:39:59PM +0900, Till Straumann wrote:
> Try this. I had it working for css.
> http://www.slac.stanford.edu/~strauman/epics/caxy/
> HTH
> - Till
> On 05/29/2016 11:41 AM, Jon Brinkmann wrote:
> >Kay,
> >Several years ago Andre Charbonneau described how to tunnel CA
> >through ssh tunnels:
> >http://www.aps.anl.gov/epics/tech-talk/2013/msg00142.php
> >The method works well for EPICS base and extensions that use the EPICS
> >libraries.  It doesn't work with CSS because CSS doesn't use those libraries.
> >I think CSS uses Java CA.  I've searched the CSS documentation and the
> >Internet in vain.  Can it be done in the current version of CSS (4.1.1)?
> >If so, how?  If not, would you consider adding that functionality?
> >Jon
> >Dr. Jon Brinkmann, Factotum			Apache Point Observatory
> >Software Engineer				2001 Apache Point Road
> >Instrument Scientist				P.O. Box 59
> >E-mail:	[email protected]			Sunspot, NM 88349-0059
> >URL:	http://www.apo.nmsu.edu/brinkmann/	Tel: 575-437-6822
Re: Unable to tunnel CSS CA through ssh tunnels Till Straumann
Dynamically refresh CSS BOY runtime OPI Zhang Yuliang
RE: Dynamically refresh CSS BOY runtime OPI Mazanec Tomáš
RE: Dynamically refresh CSS BOY runtime OPI will.rogers
Re: Dynamically refresh CSS BOY runtime OPI Kasemir, Kay
Unable to tunnel CSS CA through ssh tunnels Jon Brinkmann
Prev: calculating macros Dirk Zimoch
Next: Re: Unable to tunnel CSS CA through ssh tunnels Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Unable to tunnel CSS CA through ssh tunnels Till Straumann
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
