1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: calculating macros
To: EPICS <[email protected]>
Date: Tue, 31 May 2016 15:51:02 +0200
Hi folks
As proposed on the EPICS meeting in Lund, I have prepared a prototype implementation for calculating macros (based on R3.14.12.4).
See attached file macCore.c.
Examples
$(3+4)
${  1 + 2 * (3+4)  }
${%#04x 0x1b + 1}
It becomes interesting when the expression itself contains macros (typically as operands):
epicsEnvSet i, 5
${ $(i)+1 }
This can be used on the shell as well as in templates.
But be careful if the inner macro looks like an expression:
epicsEnvSet x, 1+4
${2*${x}}
This gives 6, not 10. Just as with C macros.
${2*(${x})}
This gives 10.
BTW, this will not fool the calculation:
epicsEnvSet 3+4, 9
${3+4}
This results in 7, not 9, which is an incompatibility to the existing macLib. (I just hope nobody has built major parts of the control system upon macro names that look like integer expressions.)
The calculation is integer only and supports the operators +-*/% as well as parentheses (), comparison < and >, and the if-then-else operator ?: (with optional 'then' operand).
Unfortunately I could not support <= >= == and != because macLib already interprets = as the default value operator. Don't try. The expression will be truncated at the =.
But with integer expressions this does not hurt too much because a<=b is a<b+1 and a==b is a-b?0:1.
An expression can be prefixed with an integer printf format like %#04x to change the resulting string. (Allowed formats: diouxXc)
If the expression contains () you cannot use $() for the calculating macro or the inner () are not parsed correctly. Use ${}.
Please try and give feedback.
Dirk
* Copyright (c) 2007 UChicago Argonne LLC, as Operator of Argonne
*     National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
*     Operator of Los Alamos National Laboratory.
* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
/* Revision-Id: [email protected]
 * Implementation of core macro substitution library (macLib)
 * The implementation is fairly unsophisticated and linked lists are
 * used to store macro values. Typically there will will be only a
 * small number of macros and performance won't be a problem. Special
 * measures are taken to avoid unnecessary expansion of macros whose
 * definitions reference other macros. Whenever a macro is created,
 * modified or deleted, a "dirty" flag is set; this causes a full
 * expansion of all macros the next time a macro value is read
 * Original Author: William Lupton, W. M. Keck Observatory
#include <ctype.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define epicsExportSharedSymbols
#include "dbDefs.h"
#include "errlog.h"
#include "dbmf.h"
#include "macLib.h"
/*** Local structure definitions ***/
 * Entry in linked list of macro definitions
typedef struct mac_entry {
    ELLNODE     node;           /* prev and next pointers */
    char        *name;          /* entry name */
    char        *type;          /* entry type */
    char        *rawval;        /* raw (unexpanded) value */
    char        *value;         /* expanded macro value */
    size_t      length;         /* length of value */
    int         error;          /* error expanding value? */
    int         visited;        /* ever been visited? */
    int         special;        /* special (internal) entry? */
    int         level;          /* scoping level */
} MAC_ENTRY;
/*** Local function prototypes ***/
 * These static functions peform low-level operations on macro entries
static MAC_ENTRY *first   ( MAC_HANDLE *handle );
static MAC_ENTRY *last    ( MAC_HANDLE *handle );
static MAC_ENTRY *next    ( MAC_ENTRY  *entry );
static MAC_ENTRY *previous( MAC_ENTRY  *entry );
static MAC_ENTRY *create( MAC_HANDLE *handle, const char *name, int special );
static MAC_ENTRY *lookup( MAC_HANDLE *handle, const char *name, int special );
static char      *rawval( MAC_HANDLE *handle, MAC_ENTRY *entry, const char *value );
static void       delete( MAC_HANDLE *handle, MAC_ENTRY *entry );
static long       expand( MAC_HANDLE *handle );
static void       trans ( MAC_HANDLE *handle, MAC_ENTRY *entry, int level,
                          const char *term, const char **rawval, char **value,
                          char *valend );
static void       refer ( MAC_HANDLE *handle, MAC_ENTRY *entry, int level,
                          const char **rawval, char **value, char *valend );
static void cpy2val( const char *src, char **value, char *valend );
static char *Strdup( const char *string );
/*** Constants ***/
 * Magic number for validating context.
#define MAC_MAGIC 0xbadcafe     /* ...sells sub-standard coffee? */
 * Flag bits
#define FLAG_SUPPRESS_WARNINGS  0x1
#define FLAG_USE_ENVIRONMENT    0x80
/*** Library routines ***/
 * Create a new macro substitution context and return an opaque handle
 * associated with the new context. Also optionally load an initial set
 * of macro definitions
long                            /* 0 = OK; <0 = ERROR */
epicsShareAPI macCreateHandle(
    MAC_HANDLE  **pHandle,      /* address of variable to receive pointer */
                                /* to new macro substitution context */
    char        *pairs[] )      /* pointer to NULL-terminated array of */
                                /* {name,value} pair strings; a NULL */
                                /* value implies undefined; a NULL */
                                /* argument implies no macros */
    MAC_HANDLE *handle;         /* pointer to macro substitution context */
    /* ensure NULL handle pointer is returned on error */
    *pHandle = NULL;
    /* allocate macro substitution context */
    handle = ( MAC_HANDLE * ) dbmfMalloc( sizeof( MAC_HANDLE ) );
    if ( handle == NULL ) {
        errlogPrintf( "macCreateHandle: failed to allocate context\n" );
        return -1;
    /* initialize context */
    handle->magic = MAC_MAGIC;
    handle->dirty = FALSE;
    handle->level = 0;
    handle->debug = 0;
    handle->flags = 0;
    ellInit( &handle->list );
    /* use environment variables if so specified */
    if (pairs && pairs[0] && !strcmp(pairs[0],"") && pairs[1] && !strcmp(pairs[1],"environ") && !pairs[3]) {
        handle->flags |= FLAG_USE_ENVIRONMENT;
    else {
        /* if supplied, load macro definitions */
        for ( ; pairs && pairs[0]; pairs += 2 ) {
            if ( macPutValue( handle, pairs[0], pairs[1] ) < 0 ) {
                dbmfFree( handle );
                return -1;
    /* set returned handle pointer */
    *pHandle = handle;
    return 0;
 * Turn on/off suppression of printed warnings from macLib calls
 * for the given handle
void
epicsShareAPI macSuppressWarning(
    MAC_HANDLE  *handle,        /* opaque handle */
    int         suppress        /* 0 means issue, 1 means suppress */
    if ( handle && handle->magic == MAC_MAGIC ) {
        handle->flags = (handle->flags & ~FLAG_SUPPRESS_WARNINGS) |
                        (suppress ? FLAG_SUPPRESS_WARNINGS : 0);
 * Expand a string that may contain macro references and return the
 * expanded string
 * This is a very basic and powerful routine. It's basically a wrapper
 * around the the translation "engine" trans()
long                            /* strlen(dest), <0 if any macros are */
                                /* undefined */
epicsShareAPI macExpandString(
    const char  *src,           /* source string */
    char        *dest,          /* destination string */
    long        capacity )      /* capacity of destination buffer (dest) */
    MAC_ENTRY entry;
    const char *s;
    char *d;
    long length;
    /* check handle */
    if ( handle == NULL || handle->magic != MAC_MAGIC ) {
        errlogPrintf( "macExpandString: NULL or invalid handle\n" );
        return -1;
    /* debug output */
    if ( handle->debug & 1 )
        printf( "macExpandString( %s, capacity = %ld )\n", src, capacity );
    /* Check size */
    if (capacity <= 1)
        return -1;
    /* expand raw values if necessary */
    if ( expand( handle ) < 0 )
        errlogPrintf( "macExpandString: failed to expand raw values\n" );
    /* fill in necessary fields in fake macro entry structure */
    entry.name  = (char *) src;
    entry.type  = "string";
    entry.error = FALSE;
    /* expand the string */
    s  = src;
    d  = dest;
    *d = '\0';
    trans( handle, &entry, 0, "", &s, &d, d + capacity - 1 );
    /* return +/- #chars copied depending on successful expansion */
    length = d - dest;
    length = ( entry.error ) ? -length : length;
    /* debug output */
        printf( "macExpandString() -> %ld\n", length );
    return length;
 * Define the value of a macro. A NULL value deletes the macro if it
 * already existed
long                            /* strlen(value) */
epicsShareAPI macPutValue(
    const char  *name,          /* macro name */
    const char  *value )        /* macro value */
    MAC_ENTRY   *entry;         /* pointer to this macro's entry structure */
    /* check handle */
        errlogPrintf( "macPutValue: NULL or invalid handle\n" );
        return -1;
        printf( "macPutValue( %s, %s )\n", name, value ? value : "NULL" );
    /* handle NULL value case: if name was found, delete entry (may be
       several entries at different scoping levels) */
    if ( value == NULL ) {
        /* FIXME: shouldn't be able to delete entries from lower scopes */
        while ( ( entry = lookup( handle, name, FALSE ) ) != NULL )
            delete( handle, entry );
        return 0;
    /* look up macro name */
    entry = lookup( handle, name, FALSE );
    /* new entry must be created if macro doesn't exist or if it only
       exists at a lower scoping level */
    if ( entry == NULL || entry->level < handle->level ) {
        entry = create( handle, name, FALSE );
        if ( entry == NULL ) {
            errlogPrintf( "macPutValue: failed to create macro %s = %s\n",
                            name, value );
            return -1;
        } else {
            entry->type = "macro";
    /* copy raw value */
    if ( rawval( handle, entry, value ) == NULL ) {
        errlogPrintf( "macPutValue: failed to copy macro %s = %s\n",
                        name, value ) ;
        return -1;
    /* return length of value */
    return strlen( value );
 * Return the value of a macro
long                            /* strlen(value), <0 if undefined */
epicsShareAPI macGetValue(
    const char  *name,          /* macro name or reference */
    char        *value,         /* string to receive macro value or name */
                                /* argument if macro is undefined */
    long        capacity )      /* capacity of destination buffer (value) */
    long        length;         /* number of characters returned */
    /* check handle */
        errlogPrintf( "macGetValue: NULL or invalid handle\n" );
        return -1;
    /* debug output */
        printf( "macGetValue( %s )\n", name );
    /* if capacity <= 1 or VALUE == NULL just return -1 / 0 for undefined /
       defined macro */
    if ( capacity <= 1 || value == NULL ) {
        return ( entry == NULL ) ? -1 : 0;
    /* if not found, copy name to value and return minus #chars copied */
        strncpy( value, name, capacity );
        return ( value[capacity-1] == '\0' ) ? - (long) strlen( name ) : -capacity;
    /* expand raw values if necessary; if fail (can only fail because of
       memory allocation failure), return same as if not found */
    if ( expand( handle ) < 0 ) {
        errlogPrintf( "macGetValue: failed to expand raw values\n" );
    /* copy value and return +/- #chars copied depending on successful
       expansion */
    strncpy( value, entry->value, capacity );
    length = ( value[capacity-1] == '\0' ) ? entry->length : capacity;
    return ( entry->error ) ? -length : length;
 * Free up all storage associated with and delete a macro substitution
 * context
epicsShareAPI macDeleteHandle(
    MAC_HANDLE  *handle )       /* opaque handle */
    MAC_ENTRY *entry, *nextEntry;
    /* check handle */
        errlogPrintf( "macDeleteHandle: NULL or invalid handle\n" );
        return -1;
    /* debug output */
        printf( "macDeleteHandle()\n" );
    /* delete all entries */
    for ( entry = first( handle ); entry != NULL; entry = nextEntry ) {
        nextEntry = next( entry );
    /* clear magic field and free context structure */
    handle->magic = 0;
    dbmfFree( handle );
    return 0;
 * Mark the start of a new scoping level
epicsShareAPI macPushScope(
    MAC_ENTRY *entry;
    /* check handle */
        errlogPrintf( "macPushScope: NULL or invalid handle\n" );
        return -1;
    /* debug output */
        printf( "macPushScope()\n" );
    /* increment scoping level */
    handle->level++;
    /* create new "special" entry of name "<scope>" */
    entry = create( handle, "<scope>", TRUE );
        handle->level--;
        errlogPrintf( "macPushScope: failed to push scope\n" );
        return -1;
    } else {
        entry->type = "scope marker";
    return 0;
 * Pop all macros defined since the last call to macPushScope()
epicsShareAPI macPopScope(
    /* check handle */
        errlogPrintf( "macPopScope: NULL or invalid handle\n" );
        return -1;
    /* debug output */
        printf( "macPopScope()\n" );
    /* check scoping level isn't already zero */
    if ( handle->level == 0 ) {
        errlogPrintf( "macPopScope: no scope to pop\n" );
        return -1;
    /* look up most recent scope entry */
    entry = lookup( handle, "<scope>", TRUE );
        return -1;
    /* delete scope entry and all macros defined since it */
    for ( ; entry != NULL; entry = nextEntry ) {
    /* decrement scoping level */
    handle->level--;
    return 0;
 * Report macro details to standard output
epicsShareAPI macReportMacros(
    const char *format = "%-1s %-16s %-16s %s\n";
    MAC_ENTRY *entry;
    /* check handle */
        errlogPrintf( "macReportMacros: NULL or invalid handle\n" );
        return -1;
    /* expand raw values if necessary; report but ignore failure */
    /* loop through macros, reporting names and values */
    printf( format, "e", "name", "rawval", "value" );
    printf( format, "-", "----", "------", "-----" );
    for ( entry = first( handle ); entry != NULL; entry = next( entry ) ) {
        /* differentiate between "special" (scope marker) and ordinary
           entries */
        if ( entry->special )
            printf( format, "s", "----", "------", "-----" );
        else
            printf( format, entry->error ? "*" : " ", entry->name,
                         entry->rawval ? entry->rawval : "",
                         entry->value  ? entry->value  : "");
    return 0;
/******************** beginning of static functions ********************/
 * Return pointer to first macro entry (could be preprocessor macro)
static MAC_ENTRY *first( MAC_HANDLE *handle )
    return ( MAC_ENTRY * ) ellFirst( &handle->list );
 * Return pointer to last macro entry (could be preprocessor macro)
static MAC_ENTRY *last( MAC_HANDLE *handle )
    return ( MAC_ENTRY * ) ellLast( &handle->list );
 * Return pointer to next macro entry (could be preprocessor macro)
static MAC_ENTRY *next( MAC_ENTRY *entry )
    return ( MAC_ENTRY * ) ellNext( ( ELLNODE * ) entry );
 * Return pointer to previous macro entry (could be preprocessor macro)
    return ( MAC_ENTRY * ) ellPrevious( ( ELLNODE * ) entry );
 * Create new macro entry (can assume it doesn't exist)
    ELLLIST   *list  = &handle->list;
    MAC_ENTRY *entry = ( MAC_ENTRY * ) dbmfMalloc( sizeof( MAC_ENTRY ) );
    if ( entry != NULL ) {
        entry->name   = Strdup( name );
        if ( entry->name == NULL ) {
            dbmfFree( entry );
            entry = NULL;
        else {
            entry->type    = "";
            entry->rawval  = NULL;
            entry->value   = NULL;
            entry->length  = 0;
            entry->error   = FALSE;
            entry->visited = FALSE;
            entry->special = special;
            entry->level   = handle->level;
            ellAdd( list, ( ELLNODE * ) entry );
    return entry;
#define SUCCESS 0
#define NOVALUE 1
#define UNTERMINATED 2
#define DIVZERO 3
static int parseExpr( const char** pp, int* v, int level );
/* Value is a number or an expression in () */
static int parseValue( const char** pp, int* v )
    int status;
    int val;
    const char *p = *pp;
    int neg = 0;
    while (isspace((unsigned char)*p)) p++;
    if (*p == '+' || *p == '-') neg = *p++ == '-';
    if (*p == '(')
        p++;
        if ((status = parseExpr(&p, &val, 0)) != SUCCESS) return status;
        if (*p++ != ')')
            printf("macLib: missing ) after '%s'\n", *pp);
            return UNTERMINATED;
    else
        char* e;
        val = strtol(p, &e, 0);
        if (e == p) return NOVALUE;
        p = e;
    if (neg) val = -val;
    *pp = p;
    *v = val;
    return SUCCESS;
/* Expr is a sum or product of Values or a conditional */
    int o = 0;
    int val0, val1, val2;
    int status = SUCCESS;
    int stat1, stat2;
    val0 = 0;
    /* handle sums and differences */
    do {
        if ((stat1 = parseValue(&p, &val1)) != SUCCESS)
            if (o && stat1 == NOVALUE)
                printf ("macLib: missing operand after '%c'\n", o);
            return stat1;
        o = *p;
        /* handle products and quotients */
        while (o == '*' || o == '/' || o == '%')
            p++;
            if ((stat2 = parseValue(&p, &val2)) != SUCCESS)
                if (stat2 == NOVALUE)
                return stat2;
            if (o == '*') val1 *= val2;
            else if (val2 == 0)
                status = DIVZERO;
                val1 = 1;
            else if (o == '/') val1 /= val2;
            else val1 %= val2;
            o = *p;
        val0 += val1;
    } while (o == '+' || o == '-');
    /* handle comparisons */
    o = *p;
    if (o == '<' || o == '>')
        p++;
        if ((stat1 = parseExpr(&p, &val1, 1)) != SUCCESS)
            if (stat1 == NOVALUE)
                printf ("macLib: missing expression after '%c'\n", o);
            return stat1;
        if (o == '<')
            val0 = (val0 < val1);
        else
            val0 = (val0 > val1);
    /* handle conditionals */
    if (*p == '?' && level == 0)
        p++;
        if (*p != ':')
            stat1 = parseExpr(&p, &val1, 0);
        else
            val1 = val0;
            stat1 = status;
        if (*p != ':')
            printf("macLib: missing : after '%s'\n", *pp);
        p++;
        stat2 = parseExpr(&p, &val2, 0);
        status = val0 ? stat1 : stat2;
        val0 = val0 ? val1 : val2;
    *v = val0;
    *pp = p;
    return status;
static MAC_ENTRY *evalExpr( MAC_HANDLE *handle, const char *expr )
    MAC_ENTRY *entry = NULL;
    int status;
    const char* p = expr;
    int value;
    char valuestr[40];
    char format[20] = "%d";
    if (*p == '%')
        int i = 1;
        p++;
        while (i < sizeof(format) && strchr(" #-+0", *p))
            format[i++] = *p++;
        while (i < sizeof(format) && strchr("0123456789", *p))
            format[i++] = *p++;
        if (i < sizeof(format) && strchr("diouxXc", *p))
            format[i++] = *p++;
            format[i] = 0;
        else
            return NULL;
    status = parseExpr(&p, &value, 0);
    if (status == DIVZERO)
        printf ("macLib: division by zero\n");
    if (status != SUCCESS)
        return NULL;
    if (*p)
        printf("macLib: rubbish at end of expression: %s\n", p);
        return NULL;
    sprintf(valuestr, format, value);
    entry = create( handle, expr, TRUE );
    if ( entry )
        entry->type = "calculation";
        if ( rawval( handle, entry, valuestr ) == NULL )
            return NULL;
    return entry;
 * Look up macro entry with matching "special" attribute by name
    MAC_ENTRY *entry;
    if ( handle->debug & 2 )
        printf( "lookup-> level = %d, name = %s, special = %d\n",
                handle->level, name, special );
    if ( (special == FALSE) ) {
        entry = evalExpr( handle, name );
        if (entry) return entry;
    /* search backwards so scoping works */
    for ( entry = last( handle ); entry != NULL; entry = previous( entry ) ) {
        if ( entry->special != special )
            continue;
        if ( strcmp( name, entry->name ) == 0 )
            break;
    if ( (special == FALSE) && (entry == NULL) &&
         (handle->flags & FLAG_USE_ENVIRONMENT) ) {
        char *value = getenv(name);
        if (value) {
            if ( entry ) {
                entry->type = "environment variable";
                    entry = NULL;
        printf( "<-lookup level = %d, name = %s, result = %p\n",
                handle->level, name, entry );
    return entry;
 * Copy raw value to macro entry
    if ( entry->rawval != NULL )
        dbmfFree( entry->rawval );
    entry->rawval = Strdup( value );
    handle->dirty = TRUE;
    return entry->rawval;
 * Delete a macro entry; requires re-expansion of macro values since this
 * macro may be referenced by another one
    ellDelete( list, ( ELLNODE * ) entry );
    dbmfFree( entry->name );
    if ( entry->value != NULL )
        free( entry->value );
    dbmfFree( entry );
 * Expand macro definitions (expensive but done very infrequently)
    MAC_ENTRY *entry;
    const char *rawval;
    char      *value;
    if ( !handle->dirty )
        return 0;
            printf( "\nexpand %s = %s\n", entry->name,
                entry->rawval ? entry->rawval : "" );
        if ( entry->value == NULL ) {
            if ( ( entry->value = malloc( MAC_SIZE + 1 ) ) == NULL ) {
                return -1;
        /* start at level 1 so quotes and escapes will be removed from
           expanded value */
        rawval = entry->rawval;
        value  = entry->value;
        *value = '\0';
        trans( handle, entry, 1, "", &rawval, &value, entry->value + MAC_SIZE );
        entry->length = value - entry->value;
        entry->value[MAC_SIZE] = '\0';
    return 0;
 * Translate raw macro value (recursive). This is by far the most complicated
 * of the macro routines and calls itself recursively both to translate any
 * macros referenced in the name and to translate the resulting name
static void trans( MAC_HANDLE *handle, MAC_ENTRY *entry, int level,
                   char *valend )
    char quote;
    const char *r;
    char *v;
    int discard;
    int macRef;
    /* return immediately if raw value is NULL */
    if ( *rawval == NULL ) return;
    /* discard quotes and escapes if level is > 0 (i.e. if these aren't
       the user's quotes and escapes) */
    discard = ( level > 0 );
    /* debug output */
        printf( "trans-> entry = %p, level = %d, capacity = %u, discard = %s, "
        "rawval = %s\n", entry, level, (unsigned int)(valend - *value), discard ? "T" : "F", *rawval );
    /* initially not in quotes */
    quote = 0;
    /* scan characters until hit terminator or end of string */
    for ( r = *rawval, v = *value; strchr( term, *r ) == NULL; r++ ) {
        /* handle quoted characters (quotes are discarded if in name) */
        if ( quote ) {
            if ( *r == quote ) {
                quote = 0;
                if ( discard ) continue;
        else if ( *r == '"' || *r == '\'' ) {
            quote = *r;
        /* macro reference if '$' followed by '(' or '{' */
        macRef = ( *r == '$' &&
                   *( r + 1 ) != '\0' &&
                   strchr( "({", *( r + 1 ) ) != NULL );
        /* macros are not expanded in single quotes */
        if ( macRef && quote != '\'' ) {
            /* Handle macro reference */
            refer ( handle, entry, level, &r, &v, valend );
        else {
            /* handle escaped characters (escape is discarded if in name) */
            if ( *r == '\\' && *( r + 1 ) != '\0' ) {
                if ( v < valend && !discard ) *v++ = '\\';
                if ( v < valend ) *v++ = *++r;
            /* copy character to output */
            else {
                if ( v < valend ) *v++ = *r;
            /* ensure string remains properly terminated */
            if ( v <= valend ) *v   = '\0';
    /* debug output */
        printf( "<-trans level = %d, length = %4u, value  = %s\n",
                     level, (unsigned int)(v - *value), *value );
    /* update pointers to next characters to scan in raw value and to fill
       in in output value (if at end of input, step back so terminator is
       still there to be seen) */
    *rawval = ( *r == '\0' ) ? r - 1 : r;
    *value  = v;
    return;
 * Expand a macro reference, handling default values and defining scoped
 * macros as encountered. This code used to part of trans(), but was
 * pulled out for ease of understanding.
    const char *r = *rawval;
    char *v = *value;
    char refname[MAC_SIZE + 1] = {'\0'};
    char *rn = refname;
    MAC_ENTRY *refentry;
    const char *defval = NULL;
    const char *macEnd;
    const char *errval = NULL;
    int pop = FALSE;
    /* debug output */
        printf( "refer-> entry = %p, level = %d, capacity = %u, rawval = %s\n",
                entry, level, (unsigned int)(valend - *value), *rawval );
    /* step over '$(' or '${' */
    r++;
    macEnd = ( *r == '(' ) ? "=,)" : "=,}";
    r++;
    /* translate name (may contain macro references); truncated
       quietly if too long but always guaranteed zero-terminated */
    trans( handle, entry, level + 1, macEnd, &r, &rn, rn + MAC_SIZE );
    refname[MAC_SIZE] = '\0';
    /* Is there a default value? */
    if ( *r == '=' ) {
        MAC_ENTRY dflt;
        int flags = handle->flags;
        handle->flags |= FLAG_SUPPRESS_WARNINGS;
        /* store its location in case we need it */
        defval = ++r;
        /* Find the end, discarding its value */
        dflt.name = refname;
        dflt.type = "default value";
        dflt.error = FALSE;
        trans( handle, &dflt, level + 1, macEnd+1, &r, &v, v);
        handle->flags = flags;
    /* extract and set values for any scoped macros */
    if ( *r == ',' ) {
        MAC_ENTRY subs;
        subs.type = "scoped macro";
        subs.error = FALSE;
        macPushScope( handle );
        pop = TRUE;
        while ( *r == ',' ) {
            char subname[MAC_SIZE + 1] = {'\0'};
            char subval[MAC_SIZE + 1] = {'\0'};
            char *sn = subname;
            char *sv = subval;
            /* translate the macro name */
            ++r;
            subs.name = refname;
            trans( handle, &subs, level + 1, macEnd, &r, &sn, sn + MAC_SIZE );
            subname[MAC_SIZE] = '\0';
            /* If it has a value, translate that and assign it */
            if ( *r == '=' ) {
                ++r;
                subs.name = subname;
                trans( handle, &subs, level + 1, macEnd+1, &r, &sv,
                      sv + MAC_SIZE);
                subval[MAC_SIZE] = '\0';
                macPutValue( handle, subname, subval );
                handle->dirty = TRUE;   /* re-expand with new macro values */
    /* Now we can look up the translated name */
    refentry = lookup( handle, refname, FALSE );
    if ( refentry ) {
        if ( !refentry->visited ) {
            /* reference is good, use it */
            if ( !handle->dirty ) {
                /* copy the already-expanded value, and its error status! */
                cpy2val( refentry->value, &v, valend );
                entry->error = refentry->error;
            } else {
                /* translate raw value */
                const char *rv = refentry->rawval;
                refentry->visited = TRUE;
                trans( handle, entry, level + 1, "", &rv, &v, valend );
                refentry->visited = FALSE;
            goto cleanup;
        /* reference is recursive */
        entry->error = TRUE;
        errval = ",recursive)";
        if ( (handle->flags & FLAG_SUPPRESS_WARNINGS) == 0 ) {
            errlogPrintf( "macLib: %s %s is recursive (expanding %s %s)\n",
                          entry->type, entry->name,
                          refentry->type, refentry->name );
    } else {
        /* no macro found by this name */
        if ( defval ) {
            /* there was a default value, translate that instead */
            trans( handle, entry, level + 1, macEnd+1, &defval, &v, valend );
            goto cleanup;
        errval = ",undefined)";
            errlogPrintf( "macLib: macro %s is undefined (expanding %s %s)\n",
                        refname, entry->type, entry->name );
    /* Bad reference, insert $(name,errval) */
    if ( v < valend ) *v++ = '$';
    if ( v < valend ) *v++ = '(';
    cpy2val( refname, &v, valend );
    cpy2val( errval, &v, valend );
cleanup:
    if (pop) {
        macPopScope( handle );
    /* debug output */
        printf( "<-refer level = %d, length = %4u, value  = %s\n",
    *rawval = r;
    *value = v;
    return;
 * Copy a string, honoring the 'end of destination string' pointer
 * Returns with **value pointing to the '\0' terminator
static void cpy2val(const char *src, char **value, char *valend)
    char *v = *value;
    while ((v < valend) && (*v = *src++)) { v++; }
    *v = '\0';
    *value = v;
 * strdup() implementation which uses our own memory allocator
static char *Strdup(const char *string )
    char *copy = dbmfMalloc( strlen( string ) + 1 );
    if ( copy != NULL )
        strcpy( copy, string );
    return copy;
Re: calculating macros Andrew Johnson
Prev: Re: EPICS Base 3.15.4 released Ralph Lange
Next: Re: Unable to tunnel CSS CA through ssh tunnels Jon Brinkmann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: archiver appliance vs. data browser Kasemir, Kay
Next: Re: calculating macros Andrew Johnson
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
