1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in updating EGU field in CSS-BOY
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 7 Jun 2016 14:04:40 +0200
Dear Shantonu,
The new Channel Access event type flag DBE_PROPERTY was introduced in EPICS 3.14.11, but proper support for the EPICS records is only available in the EPICS 3.15 series.
I do not have a good idea about how CS-Studio, BOY and CAJ are supporting this feature. I was prompting you for the versions, hoping that one of the CS-Studio people would pick your question up. (With the version numbers, they should be able to give an answer.)
Sorry...
~Ralph
On 07/06/2016 13:23, Shantonu Sahoo wrote:
Dear Ralph,
Can you tell me the exact versions of EPICS base, CSS and CAJ in which this feature is incorporated.
Shantonu Sahoo
वैज्ञानिक अधिकारी / Scientific Officer
कंप्यूटर एवं सूचना वर्ग / Computer and Informatics Group
परिवर्ती ऊर्जा साइक्लोट्रॉन केन्द्र / Variable Energy Cyclotron Center
Ph: (033) 23182300
[email protected] wrote: -----
To: Ralph Lange <[email protected]>
Sent by: [email protected]
Date: 06/06/2016 03:27PM
Cc: EPICS Tech-Talk <[email protected]>
I am using EPICS base-3.14.12.5, CS-Studio 4.1.4 , Java Utilities 3.2.0. I am not sure about the version of CAJ. I am not using EPICS CA Gateway.
Shantonu Sahoo
Ph: (033) 23182300
-----Ralph Lange <[email protected]> wrote: -----
Date: 06/06/2016 02:19PM
Cc: Shantonu Sahoo <[email protected]>
A feature to allow such updates of metadata has been added to EPICS Base and the Channel Access protocol recently.
What versions of EPICS Base (your IOC), CS-Studio (your client) and CAJ (the Java CA client library inside CS-Studio) are you using? Is there an EPICS CA Gateway involved? (If yes, what version?)
~Ralph
On 06/06/2016 10:29, Shantonu Sahoo wrote:
I am using CSS-BOY to display a process variable using "Text Update". I have checked the "Show Units" property. So, in addition to the VALue, it displays the string that is specified in the EGU field of the record. But, in the runtime, if the EGU field changes, it is not updated in the OPI until I do "Refresh OPI". In contrary, the VALue is updated smoothly.
Shantonu Sahoo
Ph: (033) 23182300
Re: Problem in updating EGU field in CSS-BOY Kasemir, Kay
Re: Problem in updating EGU field in CSS-BOY Shantonu Sahoo
Re: Problem in updating EGU field in CSS-BOY Ralph Lange
Prev: Re: motor:rrbv Torsten Bögershausen
Next: Re: motor: rval/lrvl double or long ? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem in updating EGU field in CSS-BOY Shantonu Sahoo
Next: Re: Problem in updating EGU field in CSS-BOY Kasemir, Kay
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
