1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor: rval/lrvl double or long ?
To: <[email protected]>
Date: Tue, 7 Jun 2016 14:07:36 +0200
It would also allow more than 32 bit signed. With modern motors and encoders this is not sufficient any more.
However it may necessary to modify the existing low-level motor drivers.
Dirk
On 07.06.2016 12:10, Torsten Bögershausen wrote:
The rval and lrvl fields are declared  as DBF_LONG in motorRecord.dbd.
In opposite to what is explained in documentation/motorRecord.html,
they are double here.
Does it make sense to turn them into double ?
This would ease the usage of servo motors and/or controllers
that talk engineering units on the line.
And at the same time, add the "set point dead band" ?
http://www.aps.anl.gov/epics/tech-talk/2015/msg01485.php
http://www.aps.anl.gov/epics/tech-talk/2013/msg01051.php
What are the pros and cons for long vs double ?
Re: motor: rval/lrvl double or long ? Henrique Almeida
motor: rval/lrvl double or long ? Torsten Bögershausen
Prev: Re: Problem in updating EGU field in CSS-BOY Ralph Lange
Next: Re: epicsEventSignal() question Henrique Almeida
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: motor:rrbv Torsten Bögershausen
Next: Re: motor: rval/lrvl double or long ? Henrique Almeida
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
