AFAIK not even RTEMS-4.11 is supported (but 4.10 is). See teh recently
opened https://bugs.launchpad.net/bugs/1587610
Cheers
Ben
Am 10.06.2016 um 08:25 schrieb Florian Feldbauer:
> Hey all,
> I'm currently trying to build EPICS for the Hardware Development Kit (HDK)
> of the TMS570LS3137 Microprocessor [1] running RTEMS.
> I'm using RTEMS 4.12 and tried base 3.14.12.4 and 3.15.4
> but both base versions fail to build.
> This is the failing compiler step:
> /opt/rtems/4.12/bin/arm-rtems4.12-g++
> -B/opt/rtes/4.12/arm-rtems4.12/tms570ls3137_hdk_sdram/lib/ -specs
> bsp_specs -qrtems -march=armv7-r -mthumb -mbig-endian
> -mfpu=vfpv3-d16 -mfloat-abi=hard -DUNIX -O2
> -ggdb -ffunction-sections -fdata-sections -Wall -I.
> -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc
> -I../../../src/libCom/osi/compiler/default -I.
> -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix
> -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as
> -I../../../src/libCom/bucketLib -I../../../src/libCom/calc
> -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd
> -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
> -I../../../src/libCom/ellLib -I../../../src/libCom/env
> -I../../../src/libCom/error -I../../../src/libCom/fdmgr
> -I../../../src/libCom/flex -I../../../src/libCom/freeList
> -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
> -I../../../src/libCom/log -I../../../src/libCom/macLib
> -I../../../src/libCom/misc -I../../../src/libCom/osi
> -I../../../src/libCom/pool -I../../../src/libCom/ring
> -I../../../src/libCom/taskwd -I../../../src/libCom/timer
> -I../../../src/libCom/yacc -I../../../src/libCom/yacc
> -I../../../src/libCom/yajl -I../../../include/compiler/gcc
> -I../../../include/os/RTEMS -I../../../include -c
> ../../../src/libCom/osi/epicsEvent.cpp
> In file included from ../../../src/libCom/osi/osiSock.h:21:0,
> from
> ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.h:29,
> from
> ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:31:
> ../../../src/libCom/osi/os/RTEMS/osdSock.h:68:29: error: expected
> identifier before numeric constant
> #define bzero(p,n) memset(p,0,n)
> ../../../src/libCom/osi/os/RTEMS/osdSock.h:68:29: error: expected ',' or
> '...' before numeric constant
> ../../../src/libCom/osi/os/RTEMS/osdSock.h:68:20: error: conflicting
> declaration of C function 'void memset(void*, int)'
> In file included from /opt/rtems/4.12/arm-rtems4.12/include/wchar.h:4:0,
> from
> /opt/rtems/4.12/lib/gcc/arm-rtems4.12/6.1.1/include/c++/cwchar:44,
> from
> /opt/rtems/4.12/lib/gcc/arm-rtems4.12/6.1.1/include/c++/bits/postypes.h:40,
> from
> /opt/rtems/4.12/lib/gcc/arm-rtems4.12/6.1.1/include/c++/bits/char_traits.h:40,
> from
> /opt/rtems/4.12/lib/gcc/arm-rtems4.12/6.1.1/include/c++/string:40,
> from
> ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:25:
> /opt/rtems/4.12/arm-rtems4.12/include/string.h:25:7: note: previous
> declaration 'void* memset(void*, int, size_t)'
> _PTR _EXFUN(memset,(_PTR, int, size_t));
> ../../../configure/RULES_BUILD:234: recipe for target
> 'ipAddrToAsciiAsynchronous.o' failed
> make[3]: *** [ipAddrToAsciiAsynchronous.o] Error 1
> Since I'm completely new to RTEMS maybe I forgot something, or did
> something wrong...
> Anybody has an idea?
> Cheers,
> Florian
> [1] http://processors.wiki.ti.com/index.php/TMS570LS31x_HDK_Kit
"Make it so they have to reboot after every typo." ― Scott Adams
signature.asc
Description: OpenPGP digital signature
- Re: Building EPICS for RTEMS TMS570LS3137 HDK Florian Feldbauer
- Building EPICS for RTEMS TMS570LS3137 HDK Florian Feldbauer
Re: EPICS support for LonWorks field bus? Hartman, Steven M.
<2016>
2025
2026
<2016>
2025
2026
