Hi, I have managed to solve the above issue of C++ related error messages. After this I am getting following two messages while st.cmd gets loaded: Message-1: ld 0,0, "app1.munch" BSP routine sysAtReboot() not found, epicsExit() will not be called by reboot. For reduced functionality, call rebootHookAdd(epicsExitCallAtExits) value = 15197264 = 0xe7e450 = 'P' = epics_basebin + 0xa0 Message-2: iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$ ## EPICS Base built Oct 16 2014 ############################################################################ WARNING: OS Clock time was read before being set. Using 1990-01-02 00:00:00.000000 UTC iocRun: All initialization complete value = 0 = 0x0 Any clues regarding these messages .... may be we need to set the time properly for the second case. Thanks, Stefen. On Fri, Jun 3, 2016 at 7:52 PM, Dirk Zimoch <[email protected]> wrote: Hello Stefen,
| ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
