> WARNING: OS Clock time was read before being set.
> Using 1990-01-02 00:00:00.000000 UTC
I think this message is coming because vxWorks expects by default that the boot host is running an NTP time server. You could either enable that on your Windows boot host, or tell vxWorks to use another time server.
From: [email protected] [[email protected]] on behalf of Stefen Paul [[email protected]]
Sent: Monday, June 13, 2016 1:13 AM
To: EPICS Tech Talk
Subject: Re: Error msg
I have managed to solve the above issue of C++ related error messages.
After this I am getting following two messages while st.cmd gets loaded:
Message-1:
ld 0,0, "app1.munch"
BSP routine sysAtReboot() not found, epicsExit() will not be called by reboot. For reduced functionality, call
rebootHookAdd(epicsExitCallAtExits)
value = 15197264 = 0xe7e450 = 'P' = epics_basebin + 0xa0
Message-2:
iocInit
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Oct 16 2014
value = 0 = 0x0
Any clues regarding these messages .... may be we need to set the time properly for the second case.
Stefen.
On Fri, Jun 3, 2016 at 7:52 PM, Dirk Zimoch <[email protected]<redir.aspx?REF=5A1qkSIoeLp60iRPSrmbRz7NVwenkpcSoDAiA1hhficj10OSd5PTCAFtYWlsdG86ZGlyay56aW1vY2hAcHNpLmNo>> wrote:
Hello Stefen,
I found _ZNSt9exceptionD2E (or demangled std::exception::~exception) in libstdc++.a in vxWorks 6.2, 6.3, 6.4, 6.6 and 6.7 (all vxWorks 6 I have). So If you include full C++ support in vxWorks, you should have it.
__gxx_personality_v0 is also in libstdc++.a but only in vxWorks 6.7. VxWorks 6.2 - 6.6 have __gxx_personality_sj0.
So If you have vxWorks 6.7 (or maybe higher) with C++ included, you should have the symbols.
Dirk
On 03.06.2016 15:41, Dirk Zimoch wrote:
Hi Stefen,
That basically says that your app1 makes use use of
std::exception::~exception and __gxx_personality_ but they are neither
defined in your code nor already loaded in in the system.
This is vxWorks, right?
Do you have full C++ support included in your vxWorks?
Dirk
On 03.06.2016 15:28, Stefen Paul wrote:
Hello all,
While running EPICS startup script st.cmd on vxWorks for an app that was
made successfully, I am getting following error :
/ld 0,0, "app1.munch"/
/Warning: module 0x23da5d0 holds reference to undefined symbol
_ZNSt9exceptionD2E/
/v./
__gxx_personality_/
/v0./
/ld(): module contains undefined symbol(s) and may be unusable./
/value = 0 = 0x0/
/Done executing startup script
'C:\EPICS\base\app1\iocBoot\iocapp1\st.cmd'/
Any clues what might me wrong ?
Stefen.
- Error msg Stefen Paul
- Re: Error msg Dirk Zimoch
- Re: Error msg Stefen Paul
RE: Merlin and AreaDetector giles.knap
Re: Error msg Andrew Johnson
<2016>
2025
2026
<2016>
2025
2026
