1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: seq 2.3.0 with dynamic PV-array assignment?
From: "Laznovsky Michael (PSI)" <[email protected]>
Date: Mon, 20 Jun 2016 09:13:18 +0000
Hi- just wondering if anyone out there is using seq version 2.3.0 with dynamic PV assignment
from PV arrays?  The "snc" compiler generates code with missing arguments to seq_pvAssign()
and seq_pvMonitor(), which of course then doesn't compile.
foo.st:
        float pv_PS_MODE [ 48 ];
        assign pv_PS_MODE to "" ;               // will be dynamic
        pvAssign ( pv_PS_MODE [i], buf );       // char buf[] == PV name
        pvMonitor( pv_PS_MODE [i] );
snc: foo.st -> foo.c:
        static float pv_PS_MODE[48];
        static CH_ID seqg_chid_pv_PS_MODE;
        seq_pvAssign(seqg_env, , buf);
        seq_pvMonitor(seqg_env, );
I'm asking in case someone may have seen this, and has a work-around. My alternatives are to revert
to an earlier version (does 2.2 work OK for this?), or use a clumsy scalar-PV implementation.
thanks
Mike
RE: seq 2.3.0 with dynamic PV-array assignment? Laznovsky Michael (PSI)
Prev: RE: Caget packet structure Stephen Molloy
Next: Re: EPICS connect to PLC:Illegal field value PV ;Connection timed Nick Levchenko
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: seq 2.3.0 with dynamic PV-array assignment? Laznovsky Michael (PSI)
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
