1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Caget packet structure
To: "Johnson, Andrew N." <[email protected]>
Date: Sat, 18 Jun 2016 20:09:46 +0000
Thanks Andrew and Mark.
I hadn't realised the complexity behind caget.  I'll try to find another way to get the functionality I need.
Thanks for the fast replies.
Steve
Sent: Saturday, June 18, 2016 10:00 PM
To: Stephen Molloy
Cc: [email protected]
Subject: Re: Caget packet structure
Hi Stephen,
The CA protocol isn't particularly simple so I wouldn't really recommend trying to write your own implementation even of just part of it. However there is documentation of the packet types and their contents available; if you do go into this you'll want to install the Wireshark plugin for debugging purposes, the one from Michael Davidsaver is probably the most up to date. Here's the documentation:
Don't worry about mixing versions, I don't think we actually document the most recent additions to the protocol here yet anyway.
- Andrew
Sent from my iPad
On Jun 18, 2016, at 2:44 PM, Stephen Molloy <[email protected]> wrote:
I'd like to send and receive a caget command over the network using a microcontroller.  Could someone let me know the structure of the packet that I need to send to the network?    And the structure of the packet that will come back?
Steve
Caget packet structure Stephen Molloy
Re: Caget packet structure Johnson, Andrew N.
Prev: Re: Caget packet structure Johnson, Andrew N.
Next: seq 2.3.0 with dynamic PV-array assignment? Laznovsky Michael (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
