1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Including libraries in subroutines
To: <[email protected]>
Date: Mon, 27 Jun 2016 17:03:13 -0500
Hi Stephen,
On 06/27/2016 04:53 PM, Stephen Molloy wrote:
> I have some C code that I would like to convert to a subroutine record.
> I normally build the executable with g++ using a  -lwiringPi flag,
> but I don’t know the correct way to do this in order to compile the
> EPICS subroutine.  Is there a standard place I should put the library,
> or is there some change I need to make to the Makefile (and, if so,
> which Makefile?) to get this to work?
If libwiringPi.a or .so is found in a standard system library location
such as /usr/lib or /usr/local/lib then to your Makefile that builds the
IOC executable (probably in a somethingApp/src directory) you would add
the line
  PROD_SYS_LIBS += wiringPi
which tells the build that it needs to link the IOC with this system
library after it compiles your subroutine record code found in the same
directory.
If you are building libwiringPi.{a,so} yourself as part of this IOC then
I will have more questions about how and where you are building that
library to give you the correct answer. Let's start with that one though.
- Andrew
Including libraries in subroutines Stephen Molloy
Prev: Including libraries in subroutines Stephen Molloy
Next: Re: Including libraries in subroutines Stephen Molloy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
