1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS connect to siemens PLC317-2PN/DP: connetction problem
To: "Esmaeil Tabar" <[email protected]>
Cc: [email protected]
Date: Tue, 28 Jun 2016 10:07:38 +0800 (GMT+08:00)
Hi,sir
 I just used this Open Communication Wizard to convert communication. I tried to change the parameters, but there is no effect.
 Thank you.
Look forward to your answer.
Best regards,
Jie Xu
> -----原始邮件-----
> 发件人: "Esmaeil Tabar" <[email protected]>
> 发送时间: 2016-06-28 08:02:08 (星期二)
> 收件人: "XU Jie" <[email protected]>, "[email protected]" <[email protected]>
> 抄送:
> 主题: [SPAM] RE: EPICS connect to siemens PLC317-2PN/DP: connetction problem
> Hi
> TCP connection can be configured with the integrated Profinet interface but not via NetPro. You need to configure it by programming blocks. There is also a an Open Communication Wizard (OC Wizard) on Siemens website for easy configuration of the open communication.
> https://support.industry.siemens.com/cs/ww/en/view/98957840
> Regards,
> Esmaeil Tabar | PLC Engineer| Australian Synchrotron
> p: (03) 8540 5394 | f: (03) 8540 4200
> [email protected] | www.synchrotron.org.au
> 800 Blackburn Road, Clayton, Victoria 3168
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of XU Jie
> Sent: Saturday, 25 June 2016 5:11 PM
> To: [email protected]; [email protected]
> Subject: EPICS connect to siemens PLC317-2PN/DP: connetction problem
> Hi,sir:
>    I have solved the problem about Illegal field value PV, but still cann't connetc the IOCsoft used the driver package  s7plc.tgz from PSI  to siemens PLC317-2PN/DP. Because I havn't the CP module such as CP343-1 and so on, I'm trying to use CPU integrated ProfiNet interface to achieve TCP communication between the IOCsoft and siemens PLC317-2PN/DP, but it has always problems. How to configure PLC without CP module?
> Thank you.
> Best regards,
> Jie Xu
> The detail like the following:
> #!../../bin/linux-x86_64/firstIoc
> #< envPaths
> ## Register all support components
> dbLoadDatabase("../../dbd/firstIoc.dbd",0,0)
> firstIoc_registerRecordDeviceDriver(pdbbase)
> var s7plcDebug 1
> s7plcConfigure Testsystem:0,192.168.10.152,2000,10,10,1,2000,500
> ## Load record instances
> dbLoadRecords("../../db/example.db","user=root")
> iocInit()
> Starting iocInit
> ## EPICS R3.16.0.1 $Date: Thu 2016-03-03 17:36:43 -0600$ ## EPICS Base built Jun 24 2016 ############################################################################
> s7plcInit: starting main thread
> s7plcMain: main thread started
> s7plcIoParse s7-status: station=Testsystem:0 s7plcIoParse s7-status: offs=0 s7plcIoParse s7-status: dlen=2 s7plcIoParse s7-status: B=0 s7plcIoParse s7-status: L=0xffff8001 s7plcIoParse s7-status: H=0x7fff s7plcIoParse ai-int16-1: station=Testsystem:0 s7plcIoParse ai-int16-1: offs=0 s7plcIoParse ai-int16-1: dlen=2 s7plcIoParse ai-int16-1: B=0 s7plcIoParse ai-int16-1: L=0 s7plcIoParse ai-int16-1: H=0x3e8 s7plcMain Testsystem:0: Connect to 192.168.10.152:2000 on socket 5 s7plcEstablishConnection Testsystem:0: fd=5, IP=192.168.10.152 port=2000 s7plcEstablishConnection Testsystem:0: background connect(5,...) failed: Connection refused s7plcMain Testsystem:0: connect(5, 192.168.10.152:2000) failed: Connection refused. Retry in 10 seconds s7plcMain Testsystem:0: starting send thread Testsystem:0S s7plcMain Testsystem:0: starting recv thread Testsystem:0R s7plcSendThread Testsystem:0: started s7plcReceiveThread Testsystem:0: started cas warning: Configured TCP port was unavailable.
> cas warning: Using dynamically assigned TCP port 40392, cas warning: but now two or more servers share the same UDP port.
> cas warning: Depending on your IP kernel this server may not be cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
> iocRun: All initialization complete
> ## Start any sequence programs
> #seq sncfirstIoc,"user=root"
> epics> s7plcMain Testsystem:0: Connect to 192.168.10.152:2000 on socket
> epics> 8
> s7plcEstablishConnection Testsystem:0: fd=8, IP=192.168.10.152 port=2000 s7plcEstablishConnection Testsystem:0: background connect(8,...) failed: Connection refused s7plcMain Testsystem:0: connect(8, 192.168.10.152:2000) failed: Connection refused. Retry in 10 seconds s7plcReceiveThread Testsystem:0: recv(-1, ..., 10, 0) failed: Bad file descriptor
> record (bi, "s7-status")
> field (DTYP, "S7plc stat")
> field (INP,  "@Testsystem:0")
> field (SCAN, "I/O Intr")
> field (ZNAM, "disconnected")
> field (ONAM, "connected")
> field (ZSV,  "MAJOR")
> field (FLNK, "s7-status-counter")
> record (calc, "s7-status-counter")
> field (INPA, "s7-status-counter")
> field (CALC, "A+1")
> field (FLNK, "s7-disconnect-counter")
> record (calc, "s7-disconnect-counter")
> field (INPA, "s7-status")
> field (INPB, "s7-disconnect-counter.LA") field (INPC, "s7-disconnect-counter") field (CALC, "(A=0&&B=1)?C+1:C") } record (ai, "ai-int16-1") { field (DTYP, "S7plc") field (INP,  "@Testsystem:0/0 T=INT16 L=0 H=1000") field (EGUF, "10") field (LOPR, "-10") field (HOPR, "10") field (LINR, "LINEAR") field (PREC, "2") field (SCAN, "I/O Intr") }
> -----原始邮件-----
> 发件人: "XU Jie" <[email protected]>
> 发送时间: 2016-06-23 12:09:20 (星期四)
> 收件人: [email protected], [email protected]
> 抄送:
> 主题: re:Re: EPICS connect to PLC:Illegal field value PV ;Connection timed
> Hi,sir:
>  Thank you for your help, but it still doesn't work and show the problem that: Illegal field value PV .
> Thank you.
> Best regards,
> Jie Xu
> Subject: Re: EPICS connect to PLC:Illegal field value PV ;Connection timed
> From: Nick Levchenko <[email protected]>
> To: "[email protected]" <[email protected]>
> Date: Mon, 20 Jun 2016 09:35:16 +0000
>     Hi,
> "Illegal field value PV: ai-int16-1 s7plcInitRecordAi: illegal INP field type"
> Judging by this, your EPICS isn't happy about "INP" field.
> This is what you have now:
> field (INP,  "@Testsystem:0/0 'T=INT16 L=0 H=1000'")
> Looking through this (http://epics.web.psi.ch/style/software/s7plc/s7plc.html) the obvious first thing to try would be to remove extra pair of single quotation marks that you have.
> Change
> field (INP,  "@Testsystem:0/0 'T=INT16 L=0 H=1000'") to field (INP,  "@Testsystem:0/0 T=INT16 L=0 H=1000")
> See if this helps?
> ______________________
> Nick Levchenko
> Control Systems Engineer
> Integrated Control System Division
> European Spallation Source ERIC
> P.O Box 176, SE-221 00 Lund, Sweden
> Visiting address: Tunavägen 24, Lund
> Mobile: +46 721 79 23 64
> Phone: +46 46 888 33 64
> E-mail: [email protected]
> www.esss.se
> From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
> Sent: 18 June 2016 19:00
> Subject: Tech-talk Digest, Vol 10, Issue 239
> Send Tech-talk mailing list submissions to
> 	[email protected]
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
> or, via email, send a message with subject or body 'help' to
> 	[email protected]
> You can reach the person managing the list at
> 	[email protected]
> When replying, please edit your Subject line so it is more specific than "Re: Contents of Tech-talk digest..."
> Today's Topics:
>    1. EPICS connect to PLC:Illegal field value PV ;Connection timed
>       out (XU Jie)
> Message: 1
> Date: Sat, 18 Jun 2016 16:12:24 +0800 (GMT+08:00)
> From: "XU Jie" <[email protected]>
> Subject: EPICS connect to PLC:Illegal field value PV ;Connection timed
> 	out
> Message-ID: <[email protected]>
> Content-Type: text/plain; charset=UTF-8
> Hello sir,
>   I used the driver package  s7plc.tgz from PSI and tried to connetct the EPICS IOCsoft and siemens PLC317-2PN/DP  with TCP protocol. When the IOC starts, the problems like these followed:
> Illegal field value PV: ai-int16-1 s7plcGetInIntInfo: uninitialized record
> s7plcReceiveThread Testsystem:0: read error after 0 of 10 bytes: Connection timed out
> Is the cause of the problems the ioc failed to connect with PLC? Or there are other reasons?
> Thank you.
> Best regards,
> Jie Xu
> < envPaths
> epicsEnvSet("ARCH","linux-x86_64")
> epicsEnvSet("IOC","iocfirstIocboot")
> epicsEnvSet("TOP","/home/newuser/EPICS/base-3.16.0.1/support")
> epicsEnvSet("EPICS_BASE","/home/newuser/EPICS/base-3.16.0.1")
> cd "/home/newuser/EPICS/base-3.16.0.1/support"
> dbLoadDatabase "dbd/firstIoc.dbd"
> firstIoc_registerRecordDeviceDriver pdbbase var s7plcDebug 1
> s7plcConfigure Testsystem:0,192.168.10.152,102,10,10,1,2000,500
> dbLoadRecords db/first.db
> iocInit
> Starting iocInit
> ## EPICS R3.16.0.1 $Date: Thu 2016-03-03 17:36:43 -0600$ ## EPICS Base built Jun  7 2016 ############################################################################
> s7plcMain Testsystem:0: Connect to 192.168.10.152:102 on socket 5 s7plcEstablishConnection Testsystem:0: fd=5, IP=192.168.10.152 port=102 Illegal field value PV: ai-int16-1 s7plcInitRecordAi: illegal INP field type
> #seq sncxxx,"user=newuser"
> epics> s7plcWaitForInput Testsystem:0: select(5, 2.000000 sec) timed out
> first.db
>   # map range 0 ... 1000 to 0.0000 ... 10.0000
>   field (EGUF, "10")
>   field (LOPR, "-10")
>   field (HOPR, "10")
>   field (PREC, "2")
> Tech-talk mailing list [email protected] https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
> End of Tech-talk Digest, Vol 10, Issue 239
EPICS connect to siemens PLC317-2PN/DP: connetction problem XU Jie
RE: EPICS connect to siemens PLC317-2PN/DP: connetction problem Esmaeil Tabar
Prev: RE: EPICS connect to siemens PLC317-2PN/DP: connetction problem Esmaeil Tabar
Next: RE: Call to assert failed - EPICS Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: question of data conversion Remi Faure
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
