1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Post numbers used by CA client
Date: Mon, 4 Jul 2016 14:43:00 +0000
Hi all,
I’m trying to build a Docker container for quick set-up and tear-down of EPICS instances, and I’ve run into a problem.  A CA client outside the container, but on the same host, cannot see any PV’s served from inside the container.
Looking at the network traffic with Wireshark, I can see that the server uses ports 5064 & 5065 as expected, but the ports used by the client seem to be relatively random.  If I could predict them, or (even better) force them to be specific ports, then I could expose those ports in the Docker container and (hopefully) the client and server could communicate properly.
Or perhaps this isn’t the problem, and there is some other network issue getting in my way.
(I’ve successfully run several EPICS installations on this network and from this computer, so I am confident that this is an issue with the Docker set-up.)
Hopefully I’m on the right track with my thinking, and hopefully someone can let me know how to proceed from here?
In case you’re interested, I’m documenting my work on my blog — http://www.smolloy.com/2016/07/easy-epics-implementation-with-docker/
Thanks (again) for your time,
Steve
Re: Post numbers used by CA client Ralph Lange
Prev: Re: Problem in updating EGU field in CSS-BOY Ralph Lange
Next: Re: Post numbers used by CA client Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: gddAppFuncTableStatus string pthomas
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
