1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Post numbers used by CA client
To: EPICS Tech-Talk <[email protected]>
Cc: Stephen Molloy <[email protected]>
Date: Mon, 4 Jul 2016 17:02:35 +0200
Hi Steve,
A CA client uses ephemeral ports as originating port numbers, correct. Ephemeral port numbers are indeed random, and cannot be predicted reliably.
However, if your container contains an IOC (CA server), opening ports 5064&5065 (in the default setup) for both TCP and UDP should allow any client outside the container to connect. (Not much different to a container with a web service published at port 80.) The CA client in the container would still use ephemeral port numbers for outgoing connections - do you need to publish those?
Cheers,
~Ralph
On 04/07/2016 16:43, Stephen Molloy wrote:
I’m trying to build a Docker container for quick set-up and tear-down of EPICS instances, and I’ve run into a problem. A CA client outside the container, but on the same host, cannot see any PV’s served from inside the container. Looking at the network traffic with Wireshark, I can see that the server uses ports 5064 & 5065 as expected, but the ports used by the client seem to be relatively random. If I could predict them, or (even better) force them to be specific ports, then I could expose those ports in the Docker container and (hopefully) the client and server could communicate properly.
Or perhaps this isn’t the problem, and there is some other network issue getting in my way. (I’ve successfully run several EPICS installations on this network and from this computer, so I am confident that this is an issue with the Docker set-up.)
Hopefully I’m on the right track with my thinking, and hopefully someone can let me know how to proceed from here?
In case you’re interested, I’m documenting my work on my blog — http://www.smolloy.com/2016/07/easy-epics-implementation-with-docker/
Thanks (again) for your time,
Steve
Re: Post numbers used by CA client Stephen Molloy
Prev: Post numbers used by CA client Stephen Molloy
Next: Re: gddAppFuncTableStatus string Michael Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Post numbers used by CA client Stephen Molloy
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
