1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: error when i do as howtodoserial_stramdevice.html said
To: "'l123173'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 6 Jul 2016 16:08:13 +0000
I just tried to reproduce your problem.
I built base-3.15.3, asyn 4-28 and stream (tag synApps_5_8).
I then followed the instructions here: http://www.aps.anl.gov/epics/modules/soft/asyn/R4-29/HowToDoSerial/HowToDoSerial_StreamDevice.html
It worked fine except for one thing.  I needed to change these lines in HPE3631ASup/Makefile:
DB_INSTALLS += devHPE3631A.db
DB_INSTALLS += $(TOP)/HPE3631ASup/devHPE3631A.proto
to
DB += devHPE3631A.db
DB += $(TOP)/HPE3631ASup/devHPE3631A.proto
This is the output when I run make in the example HPE3631A directory created following the instructions above.
corvette:~/scratch/HPE3631A>make
make -C ./configure install
make[1]: Entering directory `/home/epics/scratch/HPE3631A/configure'
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/home/epics/scratch/HPE3631A/configure/O.linux-x86_64'
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/configure/O.linux-x86_64'
make[1]: Leaving directory `/home/epics/scratch/HPE3631A/configure'
make -C ./HPE3631ASup install
make[1]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631ASup'
mkdir O.Common
make[2]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631ASup/O.linux-x86_64'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631ASup/O.linux-x86_64'
make[1]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631ASup'
make -C ./HPE3631AtestApp install
make[1]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp'
make -C ./src install
make[2]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/src'
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/home/epics/scratch/asyn/include   -I/home/epics/scratch/stream/include -I/usr/local/epics/base-3.15.3/include/compiler/gcc -I/usr/local/epics/base-3.15.3/include/os/Linux -I/usr/local/epics/base-3.15.3/include        -MM -MF HPE3631AtestMain.d  ../HPE3631AtestMain.cpp
Creating dbd file HPE3631Atest.dbd
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/epics/scratch/asyn/dbd -I/home/epics/scratch/stream/dbd -I/usr/local/epics/base-3.15.3/dbd -o HPE3631Atest.dbd base.dbd stream.dbd asyn.dbd drvAsynSerialPort.dbd
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/epics/scratch/asyn/dbd -I/home/epics/scratch/stream/dbd -I/usr/local/epics/base-3.15.3/dbd    -o HPE3631Atest_registerRecordDeviceDriver.cpp ../O.Common/HPE3631Atest.dbd HPE3631Atest_registerRecordDeviceDriver /home/epics/scratch/HPE3631A
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/home/epics/scratch/asyn/include   -I/home/epics/scratch/stream/include -I/usr/local/epics/base-3.15.3/include/compiler/gcc -I/usr/local/epics/base-3.15.3/include/os/Linux -I/usr/local/epics/base-3.15.3/include        -MM -MF HPE3631Atest_registerRecordDeviceDriver.d  HPE3631Atest_registerRecordDeviceDriver.cpp
make[3]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/src/O.linux-x86_64'
Installing created dbd file ../../../dbd/HPE3631Atest.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/home/epics/scratch/asyn/include   -I/home/epics/scratch/stream/include -I/usr/local/epics/base-3.15.3/include/compiler/gcc -I/usr/local/epics/base-3.15.3/include/os/Linux -I/usr/local/epics/base-3.15.3/include        -c HPE3631Atest_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/home/epics/scratch/asyn/include   -I/home/epics/scratch/stream/include -I/usr/local/epics/base-3.15.3/include/compiler/gcc -I/usr/local/epics/base-3.15.3/include/os/Linux -I/usr/local/epics/base-3.15.3/include        -c ../HPE3631AtestMain.cpp
/usr/bin/g++ -o HPE3631Atest  -L/home/epics/scratch/asyn/lib/linux-x86_64 -L/home/epics/scratch/stream/lib/linux-x86_64 -L/usr/local/epics/base-3.15.3/lib/linux-x86_64 -Wl,-rpath,/home/epics/scratch/asyn/lib/linux-x86_64 -Wl,-rpath,/home/epics/scratch/stream/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-3.15.3/lib/linux-x86_64           -rdynamic -m64            HPE3631Atest_registerRecordDeviceDriver.o HPE3631AtestMain.o    -ldbRecStd -ldbCore -lca -lCom -lstream -lasyn
Installing created executable ../../../bin/linux-x86_64/HPE3631Atest
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/src'
make -C ./Db install
make[2]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/Db'
mkdir O.Common
make[3]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/Db/O.linux-x86_64'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/Db/O.linux-x86_64'
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/Db'
make[1]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp'
make -C ./iocBoot install
make[1]: Entering directory `/home/epics/scratch/HPE3631A/iocBoot'
make -C ./iocHPE3631Atest install
make[2]: Entering directory `/home/epics/scratch/HPE3631A/iocBoot/iocHPE3631Atest'
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/epics/scratch/HPE3631A envPaths
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/iocBoot/iocHPE3631Atest'
make[1]: Leaving directory `/home/epics/scratch/HPE3631A/iocBoot'
It seems to me that you must have made a typo or some other error.
From: [email protected] [mailto:[email protected]] On Behalf Of l123173
Sent: Wednesday, July 06, 2016 7:38 AM
To: [email protected]
Subject: error when i do as howtodoserial_stramdevice.html said
Hi all,
     I used base3.15.3, synApps_5_8, Fedora 23 (64) for epics.
     I want to do the serial control as HowToDoSerial_StreamDevice.html  in the ASYN document directory.
     I try to do it as the tutorial(  howto do serail_streamdevce.html ) said. But I failed and again and again.
     The same error  and I think it is beyond what I know.
     Could you tell me how to fix it?
Regards
Li Xing
Here is the information.
[root@bogon kohzu2]# make
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.tapfiles.linux-x86_64' given more than once in the same rule
make[1]: Entering directory '/home/lyx/kohzu2/configure'
/opt/epics/base/configure/RULES_ARCHS:60: target 'inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:64: target 'linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:69: target 'O.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:85: target 'clean.linux-x86_64' given more than once in the same rule
perl -CSD /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make[1]: Circular install.linux-x86_64 <- install.linux-x86_64 dependency dropped.
make[2]: Entering directory '/home/lyx/kohzu2/configure/O.linux-x86_64'
perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/home/lyx/kohzu2/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/lyx/kohzu2/configure'
make -C ./KOHZUSup install
make[1]: Entering directory '/home/lyx/kohzu2/KOHZUSup'
mkdir O.Common
make[2]: Entering directory '/home/lyx/kohzu2/KOHZUSup/O.linux-x86_64'
make[2]: *** No rule to make target 'devKOHZU.db', needed by '../../db/devKOHZU.db'.  Stop.
make[2]: Leaving directory '/home/lyx/kohzu2/KOHZUSup/O.linux-x86_64'
/opt/epics/base/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/lyx/kohzu2/KOHZUSup'
/opt/epics/base/configure/RULES_DIRS:88: recipe for target 'KOHZUSup.install' failed
make: *** [KOHZUSup.install] Error 2
[root@bogon kohzu2]#  Entering directory '/home/lyx/kohzu2/configure'
bash: Entering: command not found...
[root@bogon kohzu2]# /opt/epics/base/confi Entering directory '/home/lyx/kohzu2/configure'
bash: /opt/epics/base/confi: No such file or directory
error when i do as howtodoserial_stramdevice.html said l123173
Prev: error when i do as howtodoserial_stramdevice.html said l123173
Next: Unreachable code in makeBaseApp.pl? Stephen Molloy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
