1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Unreachable code in makeBaseApp.pl?
Date: Thu, 7 Jul 2016 14:45:48 +0000
Hi all,
While building Docker containers, I had an error that turned out to be due to the lack of a $USER environment variable.  When makeBaseApp.pl is called, it tries to figure out the username in the GetUser subroutine, using the following command:
$user = $opt_u || $ENV{USER} || $ENV{USERNAME} || Win32::LoginName();
This command is problematic on Linux machines since it will fail if a username is not supplied via the –u flag and $USER and $USERNAME are not set.  This means that the remainder of that subroutine (where the user is queried for their name), will not be executed.
It seems to me that the Win32::LoginName() call should only be attempted if the host architecture is verified to be a Windows machine, or perhaps it could be wrapped in a try/catch in order to prevent the non-existence of Win32::LoginName from crashing the code.
Of course, it’s very possible that this issue is caused by something that I am doing wrong….
Steve
Re: Unreachable code in makeBaseApp.pl? Andrew Johnson
Prev: RE: error when i do as howtodoserial_stramdevice.html said Mark Rivers
Next: Re: Unreachable code in makeBaseApp.pl? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
