1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unreachable code in makeBaseApp.pl?
Date: Fri, 8 Jul 2016 17:52:24 +0000
On 08/07/16 18:11, "Andrew Johnson" <[email protected]> wrote:
>Does making this change result in you being prompted for a user-name?
>> === modified file 'src/makeBaseApp/makeBaseApp.pl'
>> --- src/makeBaseApp/makeBaseApp.pl      2016-05-22 03:43:09 +0000
>> +++ src/makeBaseApp/makeBaseApp.pl      2016-07-08 15:44:43 +0000
>> @@ -418,7 +418,8 @@
>>  sub GetUser {
>> -    $user = $opt_u || $ENV{USER} || $ENV{USERNAME} ||
>>Win32::LoginName();
>> +    $user = $opt_u || $ENV{USER} || $ENV{USERNAME} || getlogin();
>> +    $user = Win32::LoginName() if !$user && $^ eq 'MSWin32';
>>      unless ($user) {
>>         print "Strange, I cannot figure out your user name!\n²;
Yes, in that case the script asks me for my name.  I only tested it on my
Docker container, so it might need someone with a Windows install to make
sure it behaves in the right way.
Glad I was able to help in some small way :)
Steve
Re: Unreachable code in makeBaseApp.pl? Stephen Molloy
Re: Unreachable code in makeBaseApp.pl? Andrew Johnson
Prev: Re: Unreachable code in makeBaseApp.pl? Andrew Johnson
Next: Write to waveform record using PVUtil.writePV Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
