1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Write to waveform record using PVUtil.writePV
Date: Mon, 11 Jul 2016 11:10:42 +0000
Hello all,
Recently we created a waveform record that holds a firmware for a device. We read the firmware from a binary file and put every 4 bytes as unsigned integer into an array of integers. We found out that in order for arrays to be passed to the writePV API using a Python script, it must be a float array (either array or jarray). Can be done something like this:
Data = "" [], 'f' )
Now since we need to send unsigned integers, something like this won't work:
Data = "" [], 'l' )
Or anything other than 'f' or 'd' will give error:
java.lang.RuntimeException: Unsupported type for CA: class [J
Why does the writePV API does not accept any array other than float or double array array? The bytes to be sent are unpacked from the bin file with a specific bit pattern that should not be changed or the device is rendered unusable and needs restart.
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Re: Write to waveform record using PVUtil.writePV Kasemir, Kay
Prev: Re: Unreachable code in makeBaseApp.pl? Stephen Molloy
Next: Re: Write to waveform record using PVUtil.writePV Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
