1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: AndorCCD binning
To: "'Hinxx'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Jul 2016 21:36:15 +0000
Hi Hinko,
> OK. I guess we can expect this change to appear in 2.5, 2.6 release?
Yes, it will be in the next release.
> Would you accept a patch that would allow changing read mode?
Yes, I'd be happy to accept a patch to support changing the read mode.  I would like the patch to include:
- Updated RELEASE.md file
- Updated andorDoc.html
- Updated medm screens with widgets for the new PVs.  Other OPI screens are autoconverted from the medm screens.  If you cannot run medm then please send a screen shot of your OPI screen so I can reproduce it in medm.
-----Original Message-----
Sent: Tuesday, July 12, 2016 8:40 AM
To: Mark Rivers; [email protected]
Subject: Re: AndorCCD binning
Hi Mark,
We will probably use patched 2.4 until then.
On a related note - Andor SDK has something called SetReadMode() to
setup for different readout modes: Image, Full Vertical Binning, single
track and multi track. Currently andorCCD only works with Image mode.
Hinko
On 07/12/2016 02:56 PM, Mark Rivers wrote:
> Hi Hinko,
> Your change looks correct to me, I don't know where the factor of 2 was coming from.  I added that code back in January 2012, but I probably only tested with small values of binning (e.g. 1, 2, 3, 4).  I will make the change and test on our Andor iDus 401 camera.
> Mark
> From: [email protected] [[email protected]] on behalf of Hinxx [[email protected]]
> Sent: Tuesday, July 12, 2016 2:52 AM
> To: [email protected]
> Subject: AndorCCD binning
> Hi Mark,
> Binning handling in AD andorCCD support does not allow to produce full
> vertical binning (width x 1 image). Looking at the code I noticed that
> some magic with trying to figure out the minY might be the problem. Also
> when trying to come up with the binY values Andor SDK rejects some valid
> binning values because other parameters to SetImage() are invalid.
> unsigned int WINAPI SetImage(int hbin, int vbin, int hstart, int hend,
> int vstart, int vend)
> For example Andor Luca with 1004x1002 detector and binY set to 1002
> yields this call to the SetImage():
> SetImage(1,1002,1,1004,-1001,0)
> Of course it results in error from Andor SDK (-1001 is not valid minY).
> Probably same applies to horizontal binning..
> After changing some of the lines of the andorCCD.cpp I can successfully
> set binY to 1002 and get 1004 x 1 image:
> diff --git a/andorApp/src/andorCCD.cpp b/andorApp/src/andorCCD.cpp
> index ff09114..2ff92e0 100755
> --- a/andorApp/src/andorCCD.cpp
> +++ b/andorApp/src/andorCCD.cpp
> @@ -1060,12 +1060,12 @@
>      getIntegerParam(ADSizeY, &sizeY);
>      getIntegerParam(ADMaxSizeX, &maxSizeX);
>      getIntegerParam(ADMaxSizeY, &maxSizeY);
> -  if (minX > (maxSizeX - 2*binX)) {
> -    minX = maxSizeX - 2*binX;
> +  if (minX > (maxSizeX - binX)) {
> +    minX = maxSizeX - binX;
>        setIntegerParam(ADMinX, minX);
> -  if (minY > (maxSizeY - 2*binY)) {
> -    minY = maxSizeY - 2*binY;
> +  if (minY > (maxSizeY - binY)) {
> +    minY = maxSizeY - binY;
>        setIntegerParam(ADMinY, minY);
>      if ((minX + sizeX) > maxSizeX) {
> The call to SetImage() is now:
> SetImage(1,1002,1,1004,1,1002)
> This change might break other Andor detectors, here at ESS and with CEA
> partner we can test Andor Newton and Andor Luca.
> Thanks,
> Hinko
Re: AndorCCD binning Hinxx
RE: AndorCCD binning Mark Rivers
Prev: EPICS archiver appliance redundancy Phillip Sorensen
Next: Re: AndorCCD binning Hinxx
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AndorCCD binning Hinxx
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
