Just a little PSA. Manually copying libraries between different linux
distributions is a recipe for extremely hard to troubleshoot misbehavior.
FYI, for Debian derived distributions the "apt-file" utilities knows how
to answer the question "which package provides file X".
eg. on Debian 8 amd64
> $ apt-file search libXp.so
> libxp-dev: /usr/lib/x86_64-linux-gnu/libXp.so
On 07/25/2016 11:29 AM, Hulusi Öz wrote:
> I tried to do that but it doesn't recognize the package. On Ubuntu, it
> is also the same situation, but i installed libxpm package instead of
> it. Eventhough i did the same step in Mint,it doesnt work. Therefore, i
> copy the libXp.a file from Ubuntu's lib folder to the Mint's folder. It
> works fine now. But, thanks for your response..
> 25 Tem 2016 17:25 tarihinde "Michael Westfall" <[email protected]
> <mailto:[email protected]>> yazdı:
> You probably just needed to do:
> sudo apt-get install libxp-dev
> On Sun, Jul 24, 2016 at 12:55 PM, Hulusi Öz <[email protected]
> <mailto:[email protected]>> wrote:
> It is SOLVED..
> I take the "libXp.a" file on Ubuntu 16.04 and copy that to the
> Linux Mint "/usr/lib/x86_64-linux-gnu" path. And the problem is
> solved.
> I don't know why that doesn't work in Linux Mint, but if someone
> has this problem, this may help..
> Best Regards..
> Hulusi
> 2016-07-24 18:28 GMT+03:00 Hulusi Öz <[email protected]
> <mailto:[email protected]>>:
> Hi Everyone,
> I have already installed Epics_Base, Medm, and some other
> libraries on my other computer which is Ubuntu 16.04.
> For Linux Mint Mate 18, I installed base,extension package,
> but for MEDM, I couldn't do that.
> I have changed the
> extensions/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64 .
> I installed the libraries except libxp-dev. When I try to
> install this library,it says there are others libraries
> which refers to that. ( In Ubuntu, I couldn't also install
> that library). Then, I installed "libxpm-dev" and
> "libxmu-dev" . In Ubuntu, MEDM worked fine, but in Linux
> Mint, it doesn't work.
> It keeps saying "libXp.a" error :
> make -C ./printUtils install
> make[1]: Entering directory
> '/opt/epics/extensions/src/medm3_1_9/printUtils'
> make -C O.linux-x86_64 -f ../Makefile TOP=../../../..
> T_A=linux-x86_64 install
> make[2]: Entering directory
> '/opt/epics/extensions/src/medm3_1_9/printUtils/O.linux-x86_64'
> make[2]: Nothing to be done for 'install'.
> make[2]: Leaving directory
> make[1]: Leaving directory
> make -C ./xc install
> '/opt/epics/extensions/src/medm3_1_9/xc'
> '/opt/epics/extensions/src/medm3_1_9/xc/O.linux-x86_64'
> make -C ./medm install
> '/opt/epics/extensions/src/medm3_1_9/medm'
> '/opt/epics/extensions/src/medm3_1_9/medm/O.linux-x86_64'
> make[2]: *** No rule to make target
> '/usr/lib/x86_64-linux-gnu/libXp.a', needed by 'medm'. Stop.
> ../../../../base/configure/RULES_ARCHS:63: recipe for target
> 'install.linux-x86_64' failed
> make[1]: *** [install.linux-x86_64] Error 2
> ../../../base/configure/RULES_DIRS:70: recipe for target
> 'medm.install' failed
> make: *** [medm.install] Error 2
> Thanks in advance..
> Best Regards..
> Hulusi
> Mike Westfall
> Control Systems Software Engineer
- Re: MEDM installation error on Linux Mint (libXp.a error) Hulusi Öz
- MEDM installation error on Linux Mint (libXp.a error) Hulusi Öz
- Re: MEDM installation error on Linux Mint (libXp.a error) Michael Westfall
RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
<2016>
2025
2026
<2016>
2025
2026
