1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EpicsQT and Archiver Appliance
To: [email protected]
Cc: [email protected]
Date: Wed, 27 Jul 2016 10:52:03 -0400
> ImportError: No module named EPICSEvent_pb2
This is protobuf generated python code (yes really :P ) which should
have been created by the setup.py build step (specifically the
build_protobuf step).
> However, if I go into the twisted directory it will start.
There are two way (the I've tested) to run carchivetools, a full install
"setup.py install ...." then add the destination directory to
PYTHONPATH.  The destination directory should contain
"carchive/backend/EPICSEvent_pb2.py".
The other is an in-place build (for development/testing) as described at
the bottom of /README.md.  This will generated EPICSEvent_pb2.py in the
source tree.  So running from, or adding to PYTHONPATH, the root of the
source tree should work.  It sounds like you've done this.
Before we get to a2aproxy, have you succeeded in getting the CLI tools
(eg. 'arinfo') to talk to AA?  The following should serve as a template.
> cat <<EOF > test.conf
> [DEFAULT]
> urltype = appl
> host = http://localhost:17665/mgmt/bpl/getApplianceInfo
> EOF
> arinfo -C test.conf -vvv -a '*'
> ...a2aproxy will crashes with an
> exception 'dict' object has no attribute 'getint'. All the gory details
> follow...
This smells like a bug.  This shouldn't be a 'dict', but rather a
'carchive._conf.ConfigDict'.
https://github.com/epicsdeb/carchivetools/issues/8
On 07/26/2016 09:15 AM, [email protected] wrote:
> Hello Michael,
> I have installed carchivetools and it looks like is will do exactly what
> I need but I think I am having a problem connecting it to AA. I am using
> twistd (the Twisted daemon) 13.2.0 and Python 2.7.6. I compiled and
> installed using setup.py and installed it under su. It all went smoothly
> and twistd –help now shows a2aproxy
> The problem is when I query a2aproxy with archiver.names or values
> (anything that seems to connect to AA). a2aproxy will crashes with an
> follow...
> I have an archiver appliance running on  localhost. The mgmt and
> retrieval  urls are running on different ports but I believe that is
> normal for the full setup of AA.  From a browser,
> http://localhost:17665/mgmt/bpl/getApplianceInfo,
> AA will return:
> {"engineURL":"http:\/\/localhost:17666\/engine\/bpl","identity":"appliance0","retrievalURL":"http:\/\/localhost:17668\/retrieval\/bpl","clusterInetPort":"localhost:16670","etlURL":"http:\/\/localhost:17667\/etl\/bpl","version":"Archiver
> Appliance Version
> 0.0.1_SNAPSHOT_13-May-2016T11-23-57","mgmtURL":"http:\/\/localhost:17665\/mgmt\/bpl","dataRetrievalURL":"http:\/\/localhost:17668\/retrieval"}
> So, I start the a2aproxy via:
> twistd  -n a2aproxy -P 8888 -A localhost:17665 (and several combinations
> of this with http:// etc during testing)
> If I start from outside the twisted plugin directory it will crash, this
> was my first worry as I thought that it was installed:
> However, if I go into the twisted directory it will start. Ok, so I
> moved on, everything looks good. I can send and return the archiver.info
> call and get the hardcoded response from the proxy.
> However, if I  send:
> archiver.names(1,"rga")
> Instead of getting a list of matching PVs from the AA it crashed with:
> 2016-07-26 13:53:40+0100 [HTTPChannel,0,148.79.212.92]
> INFO:carchive.a2aproxy.resource Request: archiver.names(1, 'rga')
> WARNING:carchive.a2aproxy.resource Cleanup of request with no
> reply
> 2016-07-26 13:53:40+0100 [HTTPChannel,0,148.79.212.92] 148.79.212.92 - -
> [26/Jul/2016:12:53:39 +0000] "POST /cgi-bin/ArchiveDataServer.cgi
> HTTP/1.1" 500 - "-" "Python-xmlrpc/3.5"
> ERROR:carchive.a2aproxy.resource Unhandled execption during request:
> Traceback (most recent call last):
>                   File
> "/usr/lib/python2.7/dist-packages/twisted/web/resource.py", line 250, in
> render
>                     return m(request)
>                   File
> "/usr/local/lib/python2.7/dist-packages/carchive/a2aproxy/resource.py",
> line 106, in render_POST
>                     Dinfo = self.fetchInfo()
>                   File
> line 73, in fetchInfo
>                     D = getArchive({'url':self.infourl})
>                   File
> "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 1237,
> in unwindGenerator
>                     return _inlineCallbacks(None, gen, Deferred())
>                 --- <exception caught here> ---
>                   File
> "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 1099,
> in _inlineCallbacks
>                     result = g.send(result)
>                   File
> "/usr/local/lib/python2.7/dist-packages/carchive/backend/appl.py", line
> 208, in getArchive
>                     maxRequests=conf.getint('maxrequests', 100))
>                 exceptions.AttributeError: 'dict' object has no
> attribute 'getint'
> So, I thought that maybe the AA address was not getting set correctly in
> the proxy startup so I put a print statement into
> ./carchivetools-master/carchive/a2aproxy/resource.py:
> def buildResource(infourl=None):
>     if not infourl.startswith('http') and infourl.find('/')==-1:
>         # only host:port is provided, use default URL
>         infourl = "http://%s/mgmt/bpl/getApplianceInfo"%infourl
>     C = DataServer()
>     C.infourl = infourl
>     print(infourl)
> This printed out the correct url for AA:
> Best regards,
> Rory
Re: EpicsQT and Archiver Appliance Pete Jemian
RE: EpicsQT and Archiver Appliance rory.clarke
Re: EpicsQT and Archiver Appliance rory.clarke
Prev: Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Hulusi Öz
Next: Re: EpicsQT and Archiver Appliance Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EpicsQT and Archiver Appliance rory.clarke
ANJ, 28 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
