1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EpicsQT and Archiver Appliance
To: <[email protected]>
Date: Tue, 26 Jul 2016 13:15:48 +0000
Hello Michael,
I have installed carchivetools and it looks like is will do exactly what I need but I think I am having a problem connecting it to AA. I am using twistd (the Twisted daemon) 13.2.0 and Python 2.7.6. I compiled and installed using setup.py and installed it under su. It all went smoothly and twistd –help now shows a2aproxy
The problem is when I query a2aproxy with archiver.names or values (anything that seems to connect to AA). a2aproxy will crashes with an exception 'dict' object has no attribute 'getint'. All the gory details follow...
I have an archiver appliance running on  localhost. The mgmt and retrieval  urls are running on different ports but I believe that is normal for the full setup of AA.  From a browser, http://localhost:17665/mgmt/bpl/getApplianceInfo,
AA will return:
{"engineURL":"http:\/\/localhost:17666\/engine\/bpl","identity":"appliance0","retrievalURL":"http:\/\/localhost:17668\/retrieval\/bpl","clusterInetPort":"localhost:16670","etlURL":"http:\/\/localhost:17667\/etl\/bpl","version":"Archiver Appliance Version 0.0.1_SNAPSHOT_13-May-2016T11-23-57","mgmtURL":"http:\/\/localhost:17665\/mgmt\/bpl","dataRetrievalURL":"http:\/\/localhost:17668\/retrieval"}
So, I start the a2aproxy via:
twistd  -n a2aproxy -P 8888 -A localhost:17665 (and several combinations of this with http:// etc during testing)
If I start from outside the twisted plugin directory it will crash, this was my first worry as I thought that it was installed:
ImportError: No module named EPICSEvent_pb2
However, if I go into the twisted directory it will start. Ok, so I moved on, everything looks good. I can send and return the archiver.info call and get the hardcoded response from the proxy.
However, if I  send:
archiver.names(1,"rga")
Instead of getting a list of matching PVs from the AA it crashed with:
2016-07-26 13:53:40+0100 [HTTPChannel,0,148.79.212.92] INFO:carchive.a2aproxy.resource Request: archiver.names(1, 'rga')
2016-07-26 13:53:40+0100 [HTTPChannel,0,148.79.212.92] WARNING:carchive.a2aproxy.resource Cleanup of request with no reply
2016-07-26 13:53:40+0100 [HTTPChannel,0,148.79.212.92] 148.79.212.92 - - [26/Jul/2016:12:53:39 +0000] "POST /cgi-bin/ArchiveDataServer.cgi HTTP/1.1" 500 - "-" "Python-xmlrpc/3.5"
2016-07-26 13:53:40+0100 [HTTPChannel,0,148.79.212.92] ERROR:carchive.a2aproxy.resource Unhandled execption during request: Traceback (most recent call last):
                  File "/usr/lib/python2.7/dist-packages/twisted/web/resource.py", line 250, in render
                    return m(request)
                  File "/usr/local/lib/python2.7/dist-packages/carchive/a2aproxy/resource.py", line 106, in render_POST
                    Dinfo = self.fetchInfo()
                  File "/usr/local/lib/python2.7/dist-packages/carchive/a2aproxy/resource.py", line 73, in fetchInfo
                    D = getArchive({'url':self.infourl})
                  File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 1237, in unwindGenerator
                    return _inlineCallbacks(None, gen, Deferred())
                --- <exception caught here> ---
                  File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 1099, in _inlineCallbacks
                    result = g.send(result)
                  File "/usr/local/lib/python2.7/dist-packages/carchive/backend/appl.py", line 208, in getArchive
                    maxRequests=conf.getint('maxrequests', 100))
                exceptions.AttributeError: 'dict' object has no attribute 'getint'
So, I thought that maybe the AA address was not getting set correctly in the proxy startup so I put a print statement into
./carchivetools-master/carchive/a2aproxy/resource.py:
def buildResource(infourl=None):
    if not infourl.startswith('http') and infourl.find('/')==-1:
        # only host:port is provided, use default URL
        infourl = "http://%s/mgmt/bpl/getApplianceInfo"%infourl
    C = DataServer()
    C.infourl = infourl
    print(infourl)
This printed out the correct url for AA: http://localhost:17665/mgmt/bpl/getApplianceInfo
Best regards,
Rory
Re: EpicsQT and Archiver Appliance Michael Davidsaver
Prev: Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Martin L. Smith
Next: Re: Inconsistency in devAsynOctet for stringout and waveform records Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EpicsQT and Archiver Appliance Andrew C. Starritt
Next: Re: EpicsQT and Archiver Appliance Michael Davidsaver
ANJ, 27 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
