Subject: |
Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers |
"Martin L. Smith" <[email protected]> |
To: |
Date: |
Tue, 26 Jul 2016 06:06:08 -0500 |
Hi Hulusi,
It sounds like if you don't have the stream option for the DTYP field in VDCT
then stream may not be included in your dbd file which you loaded into VDCT to
start it.
Also looking at the IOC boot output:
If this command loaded properly and it appears that it did ...
dbLoadDatabase("../../dbd/helloWorldIOC.dbd",0,0)
Your IOC is probably being started from a directory other than /opt/epics/
so for the line:
dbLoadRecords("db/arduino.db","PORT='SERIALPORT'")
No such file or directory dbRead opening file db/arduino.db
This assumes that your IOC is currently in the EPICS top directory but I suspect
it is not. You can try changing this line to:
dbLoadRecords("../../db/arduino.db","PORT='SERIALPORT'")
and see if you get a different error message and that the IOC at least finds the
database file. Or you can add the line:
cd ${TOP}
right before dbLoadRecords("db/arduino.db","PORT='SERIALPORT'")
Also try un-commenting the line below in your st.cmd file as this is where
${TOP} will be defined at for your IOC.
#< envPaths
Marty
On 07/26/2016 03:32 AM, Hulusi Öz wrote:
I understand,sir and thank you for recommendation. However, the thing is that
whenever I try to make a simple example, the program can't read the database
file (just I wrote at the first message <No such file or directory dbRead
opening ..> .
You said that they don't come with EPICS BASE, then I try to make a simple
example which includes the same records but at this time both are digital. I
also try to write protocol file (arduino.proto) . That's OK so far.
In somehow, when I tend to write database file (.db) and direct the path of that
(.db) in the "st.cmd" file, I've got an error which says that Record initialised
not correctly..
I also tried to make the same example by using VDCT. In ai and ao records, I set
the DTYP as stream ( but, by default there is no option in VDCT). I've got the
same error .
However, when i say genaretes macros in VDCT (it put a script in .db file like
this (template { } )). At this time, I've got an error exactly the same as I
wrote the first message.
I thougt, the problem may be caused by PORT definitions,maybe the program can't
connect the data. But, I did the exactly same things in examples.
Thanks in advance..
Best Regards..
2016-07-26 0:29 GMT+03:00 Mark Rivers <[email protected]
<mailto:[email protected]>>:
If you have a computer with a serial port (or USB to serial adapter) you can
just connect pin 2 to pin 3 (loopback) and can write code that sends
messages and receives messages over hardware. Simple to set up, and it will
get you going with real hardware. You can use StreamDevice, the asynRecord,
and other code for testing an experimenting.____
__ __
Mark____
__ __
__ __
*From:*Hulusi Öz [mailto:[email protected] <mailto:[email protected]>]
*Sent:* Monday, July 25, 2016 2:58 PM
*To:* Mark Rivers; [email protected] <mailto:[email protected]>
*Subject:* Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers____
__ __
How can i solve that problem ? Can I re-configure it with EPICS functionally
?____
__ __
Yes, I want to talk a real hardware. But, since I am new at this area, I
thought, if I can do database stuff with arduino in terms of serial
communication, I may handle with a real hardware.____
I don't know what the things requires for Caen digitizier, the things may
change from hardware to hardware. I mean, talking to arduino and Caen
digitizer may not be the same stuff. But, I've just started at some point.____
__ __
Best Regards..____
__ __
2016-07-25 22:51 GMT+03:00 Mark Rivers <[email protected]
<mailto:[email protected]>>:____
The files arduino.db and /opt/epics/helloWorld/db/helloWorldIOC.db are some
local files that were specific to the application in that Web page you
found. They don’t come with EPICS base.____
____
What is it you would like to try before beginning to work with the Caen
digitizer? Talking to real hardware?____
____
Mark____
____
____
<mailto:[email protected]>] *On Behalf Of *Hulusi Öz
*Sent:* Monday, July 25, 2016 2:44 PM
*To:* [email protected] <mailto:[email protected]>
*Subject:* EPICS-Arduino Serial Communication via Asyn-Stream Drivers____
____
Hi Everyone,____
____
I have just been dealing with EPICS and its applications since a few weeks.
I've done basic things such as creating IOC, making MEDM
display,communicating Octave and etc..And I've got help most of the time in
this tech-talk.____
____
I am now dealing with communication a device that is supported by EPICS. I
have got a Digitizier which is manufactured by CAEN. But before I deal with
that device, I want to figure out the database configuration in an
application. Therefore, I research on the Internet and in this website. I
found a quite basic example which is :____
____
(/http://www.smolloy.com/2015/12/epics-serial-communication-with-arduino/)/.____
____
I've just done the previous sections of this example,and also followed the
steps in that link. However, when I run it I've got nothing. ____
More specifically :____
____
#!/opt/epics/helloWorldIOC/bin/linux-x86_64/helloWorldIOC____
## You may have to change helloWorldIOC to something else____
## everywhere it appears in this file____
#< envPaths____
epicsEnvSet(STREAM_PROTOCOL_PATH,"helloWorldIOCApp/Db")____
## Register all support components____
dbLoadDatabase("../../dbd/helloWorldIOC.dbd",0,0)____
helloWorldIOC_registerRecordDeviceDriver(pdbbase) ____
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyACM0",0,0,0)____
asynSetOption("SERIALPORT",-1,"baud","115200")____
asynSetOption("SERIALPORT",-1,"bits","8")____
asynSetOption("SERIALPORT",-1,"parity","none")____
asynSetOption("SERIALPORT",-1,"stop","1")____
asynSetOption("SERIALPORT",-1,"clocal","Y")____
asynSetOption("SERIALPORT",-1,"crtscts","N")____
dbLoadRecords("db/arduino.db","PORT='SERIALPORT'")____
filename="../dbLexRoutines.c" line number=240____
No such file or directory dbRead opening file db/arduino.db____
## Load record instances____
dbLoadRecords("/opt/epics/helloWorld/db/helloWorldIOC.db","user=hulusi")____
/opt/epics/helloWorld/db/helloWorldIOC.db____
iocInit()____
Starting iocInit____
############################################################################____
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$____
## EPICS Base built Jul 21 2016____
iocRun: All initialization complete____
## Start any sequence programs____
#seq snchelloWorldIOC,"user=hulusi"____
____
I guess, the problem is due to the colored line in this output. But I'm not
sure that.____
Is it so ? If it is like that, how can I figure it out ?____
If it isn't like that, what does the thing cause this problem ?____
____
Thanks in advance..____
Best regards..____
____
Hulusi____
__ __
- EPICS-Arduino Serial Communication via Asyn-Stream Drivers Hulusi Öz
- RE: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Mark Rivers
- Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Hulusi Öz
Re: EpicsQT and Archiver Appliance rory.clarke
<2016>
2025
2026
<2016>
2025
2026
