1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers
To: Mark Rivers <[email protected]>, [email protected]
Date: Tue, 26 Jul 2016 11:32:56 +0300
I understand,sir and thank you for recommendation. However, the thing is that whenever I try to make a simple example, the program can't read the database file (just I wrote at the first message <No such file or directory dbRead opening ..> .
You said that they don't come with EPICS BASE, then I try to make a simple example which includes the same records but at this time both are digital. I also try to write protocol file (arduino.proto) . That's OK so far.
In somehow, when I tend to write database file (.db) and direct the path of that (.db) in the "st.cmd" file, I've got an error which says that Record initialised not correctly..
I also tried to make the same example by using VDCT. In ai and ao records, I set the DTYP as stream ( but, by default there is no option in VDCT). I've got the same error .
However, when i say genaretes macros in VDCT (it put a script in .db file like this (template { } )). At this time, I've got an error exactly the same as I wrote the first message.
I thougt, the problem may be caused by PORT definitions,maybe the program can't connect the data. But, I did the exactly same things in examples.
Thanks in advance..
Best Regards..
2016-07-26 0:29 GMT+03:00 Mark Rivers <[email protected]>:
If you have a computer with a serial port (or USB to serial adapter) you can just connect pin 2 to pin 3 (loopback) and can write code that sends messages and receives messages over hardware.  Simple to set up, and it will get you going with real hardware.  You can use StreamDevice, the asynRecord, and other code for testing an experimenting.
Sent: Monday, July 25, 2016 2:58 PM
To: Mark Rivers; [email protected]
How can i solve that problem ? Can I re-configure it with EPICS functionally ?
Yes, I want to talk a real hardware. But, since I am new at this area, I thought, if I can do database stuff with arduino in terms of serial communication, I may handle with a real hardware.
I don't know what the things requires for Caen digitizier, the things may change from hardware to hardware. I mean, talking to arduino and Caen digitizer may not be the same stuff. But, I've just started at some point.
Best Regards..
2016-07-25 22:51 GMT+03:00 Mark Rivers <[email protected]>:
The files arduino.db and /opt/epics/helloWorld/db/helloWorldIOC.db are some local files that were specific to the application in that Web page you found.  They don’t come with EPICS base.
What is it you would like to try before beginning to work with the Caen digitizer?  Talking to real hardware?
From: [email protected] [mailto:[email protected]] On Behalf Of Hulusi Öz
Sent: Monday, July 25, 2016 2:44 PM
To: [email protected]
Subject: EPICS-Arduino Serial Communication via Asyn-Stream Drivers
Hi Everyone,
I have just been dealing with EPICS and its applications since a few weeks. I've done basic things such as creating IOC, making MEDM display,communicating Octave and etc..And I've got help most of the time in this tech-talk.
I am now dealing with communication a device that is supported by EPICS. I have got a Digitizier which is manufactured by CAEN. But before I deal with that device, I want to figure out the database configuration in an application. Therefore, I research on the Internet and in this website. I found a quite basic example which is :
I've just done the previous sections of this example,and also followed the steps in that link. However, when I run it I've got nothing.
More specifically :
#!/opt/epics/helloWorldIOC/bin/linux-x86_64/helloWorldIOC
## You may have to change helloWorldIOC to something else
## everywhere it appears in this file
#< envPaths
epicsEnvSet(STREAM_PROTOCOL_PATH,"helloWorldIOCApp/Db")
dbLoadDatabase("../../dbd/helloWorldIOC.dbd",0,0)
helloWorldIOC_registerRecordDeviceDriver(pdbbase)
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyACM0",0,0,0)
asynSetOption("SERIALPORT",-1,"baud","115200")
asynSetOption("SERIALPORT",-1,"bits","8")
asynSetOption("SERIALPORT",-1,"parity","none")
asynSetOption("SERIALPORT",-1,"stop","1")
asynSetOption("SERIALPORT",-1,"clocal","Y")
asynSetOption("SERIALPORT",-1,"crtscts","N")
dbLoadRecords("db/arduino.db","PORT='SERIALPORT'")
filename="../dbLexRoutines.c" line number=240
No such file or directory dbRead opening file db/arduino.db
## Load record instances
dbLoadRecords("/opt/epics/helloWorld/db/helloWorldIOC.db","user=hulusi")
No such file or directory dbRead opening file /opt/epics/helloWorld/db/helloWorldIOC.db
iocInit()
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Jul 21 2016
## Start any sequence programs
#seq snchelloWorldIOC,"user=hulusi"
I guess, the problem is due to the colored line in this output. But I'm not sure that.
Is it so ? If it is like that, how can I figure it out ?
If it isn't like that, what does the thing cause this problem ?
Thanks in advance..
Best regards..
Hulusi
Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Martin L. Smith
Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Hulusi Öz
RE: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Mark Rivers
Prev: RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Next: Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Mark Rivers
ANJ, 27 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
