1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: NDArrayPool::alloc failing
To: <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>
Date: Tue, 2 Aug 2016 09:09:23 +0000
This rings a bell. A while ago I started to do something like this. My idea was to better support cameras/drivers that want to manage the image memory (and avoid superfluous copies). A callback can be registered and you can decide whether to re-use or free the memory. It does not address the issue of some plugins holding on (forever?) to their latest received image - but I think that's a bit of a naughty behaviour...
The commits are rather old and would need to be rebased on top of the latest ADCore master branch...
https://github.com/ulrikpedersen/ADCore/commit/3e2910680b5d65ffb881304cff49cf568f13e80c and https://github.com/ulrikpedersen/ADCore/commit/db7199a110d203c7712b66ac925145ffb54b5966
Cheers,
Ulrik
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 29 July 2016 17:39
To: 'Michael Davidsaver'; [email protected]; 'Phil Atkin'
Hi Michael,
This is an excellent suggestion.
Phil, this should solve your problem.  Your driver will get a callback when the array has been released.  You can then do what you want with the buffer pointer, being confident that no plugin is using it.  If you want to implement it in NDArrayPool and NDArray you can then issue a pull request on Github.
From: [email protected] [mailto:[email protected]] On Behalf Of Michael Davidsaver
Sent: Friday, July 29, 2016 9:37 AM
To: [email protected]
Subject: Re: NDArrayPool::alloc failing
On 07/29/2016 09:29 AM, Mark Rivers wrote:
> We could add an NDArray::getReferenceCount method.  If you have the array reserved and getReferenceCount=1 then you can be sure all the plugins have released it.
A good interface to handle this sort of situation would be for
NDArrayPool::alloc() to accept a callback function pointer to "cleanup"
the user provided buffer when the NDArray ref. count falls to zero.
Re: NDArrayPool::alloc failing Phil Atkin
RE: NDArrayPool::alloc failing Mark Rivers
Re: NDArrayPool::alloc failing Michael Davidsaver
Prev: Re: shell command in medm Southern, Tim
Next: PCASpy 0.6.2 Wang Xiaoqiang (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: NDArrayPool::alloc failing Mark Rivers
Next: Re: NDArrayPool::alloc failing Phil Atkin
ANJ, 03 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
