I understand sir, but I'm confused about which module part I should use. I mean, I've used asynSerialPort so far and I'm trying to use asynPortConfigure and asynGPIB module parts, right now. Is that acceptable for using with asynSerialPort or the other modules ? Or should I configure somethings inside the application ? I couldn't relate something these configurations, so I'm sorry if I miss something important from your suggestions. Thanks in advance.Best Regards.. Hulusi Oz 2016-08-08 15:33 GMT+03:00 Mark Rivers <[email protected]>: Yes, can include those libraries in your EPICS application. That is exactly what the Measurement Computing examples I mentioned in my previous message do. They use the library from Measurement Computing to communicate with Measurement Computing devices. You will do something very similar, using the Caen libraries to communicate with the Caen device.
| ANJ, 08 Aug 2016 |
Home
News
About
Talk
Base
Modules
Extensions
