1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Multiple device support for a record type
To: Stefen Paul <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 12 Aug 2016 10:55:41 -0500
Hi again Stefen,
On 08/12/2016 12:37 AM, Stefen Paul wrote:
> Is there a way to include device support globally (at the EPICS base
> level) so that I do not need to included it every time at the individual
> application level and the support is automatically available to all the
> subsequently created applications made using makeBaseApp.
There are several ways you could do this.
1. The simplest way might be to add your device support to Base itself,
but I wouldn't really recommend that as you then have to repeat the
process every time you want to install a new version of Base.
2. The standard way to provide common device support types is to build
them as a support module which all your IOC applications build against.
The module creates a library with its compiled device support C files
in, and also provides the related DBD files. IOC applications then point
to this module in their configure/RELEASE file, and in their
src/Makefile they specify that the support DBD file be included in the
IOC's DBD file, and that the IOC binary be linked against the support
library. See almost any available support module for examples on how to
do this.
3. If you want to simplify method 2 above even further you can provide
your own template(s) for the makeBaseApp.pl script to use which already
have the module integrated (i.e. the above steps have already been
done). This is less commonly done and I don't think we have written
instructions on how to actually do it, but the functionality is there if
you want it (ask for help on tech-talk if you want to try this).
- Andrew
Multiple device support for a record type Stefen Paul
Re: Multiple device support for a record type Ralph Lange
Re: Multiple device support for a record type Stefen Paul
Prev: RE: building EPICS base-13.15.4 on Windows 10 Lee, William R. (LARC-D304)[Jacobs Technology, Inc.]
Next: Re: Is there any support for EPICS for IronPython (or anyone working on it)? Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Multiple device support for a record type Stefen Paul
Next: Questions about Data browser in CSS lzf neu
ANJ, 12 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
