Are you running a 32-bit or 64-bit version of Linux? You are building the 32-bit version of EPICS (linux-x86). If you have a 64-bit Linux system it is possible that you are missing some 32-bit libraries and you should do the following
export EPICS_HOST_ARCH=linux-x86_64
Then you will be building for 64-bit EPICS. See if that also gets an error.
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Tuesday, August 16, 2016 6:17 AM
To: [email protected]; [email protected]
Subject: RE: installation of synapps_5_8 in ubuntu
You should send the complete output when you build in the autosave directory
make clean uninstall
make
Mar
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Tuesday, August 16, 2016 6:11 AM
Subject: installation of synapps_5_8 in ubuntu
I have copied synapps_5_8 under '/opt/epics'.
epics-base is already build under /opt/epics/base-3.15.3
msi is under /opt/epics/extensions/src/msi1.7
When I am trying to build synapps with areaDetector by using 'make' command
I am getting following errors.
/opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86/libautosave.so:
undefined reference to `_dl_sysinfo'
undefined reference to `__syscall_error'
collect2: error: ld returned 1 exit status
I am new to linux and could not get any suggestions from google.
Please help me
Thank you.
- RE: installation of synapps_5_8 in ubuntu avanish
- installation of synapps_5_8 in ubuntu avanish
- RE: installation of synapps_5_8 in ubuntu Mark Rivers
<2016>
2025
2026
<2016>
2025
2026
