I am having a 32-bit linux.
> ---------------------------- Original Message ----------------------------
> Subject: RE: installation of synapps_5_8 in ubuntu
> From: "Mark Rivers" <[email protected]>
> Date: Tue, August 16, 2016 4:56 pm
> To: "[email protected]" <[email protected]>
> Are you running a 32-bit or 64-bit version of Linux? You are building the
> 32-bit version of EPICS (linux-x86). If you have a 64-bit Linux system it
> is possible that you are missing some 32-bit libraries and you should do
> the following
> export EPICS_HOST_ARCH=linux-x86_64
> Then you will be building for 64-bit EPICS. See if that also gets an
> error.
> Mark
> From: [email protected] [[email protected]] on
> behalf of Mark Rivers [[email protected]]
> Sent: Tuesday, August 16, 2016 6:17 AM
> To: [email protected]; [email protected]
> You should send the complete output when you build in the autosave
> directory
> make clean uninstall
> make
> Mar
> behalf of [email protected] [[email protected]]
> Sent: Tuesday, August 16, 2016 6:11 AM
> Subject: installation of synapps_5_8 in ubuntu
> Hi,
> I have copied synapps_5_8 under '/opt/epics'.
> epics-base is already build under /opt/epics/base-3.15.3
> msi is under /opt/epics/extensions/src/msi1.7
> When I am trying to build synapps with areaDetector by using 'make'
> command
> I am getting following errors.
> /opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86/libautosave.so:
> undefined reference to `_dl_sysinfo'
> undefined reference to `__syscall_error'
> collect2: error: ld returned 1 exit status
> I am new to linux and could not get any suggestions from google.
> Please help me
> Thank you.
- installation of synapps_5_8 in ubuntu avanish
- RE: installation of synapps_5_8 in ubuntu Mark Rivers
RE: installation of synapps_5_8 in ubuntu avanish
<2016>
2025
2026
<2016>
2025
2026
