1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Variable SCAN Intervall and Roundoff function
To: [email protected]
Date: Tue, 16 Aug 2016 15:32:24 +0200
i have two question für a simple controlapplication.
1.) I have a calcout-record which can increase or decrease a value
Now I am want to implement a simple variable SCAN-intervall to increase every 60 seconds or every hour . But I don't know which is the best way to do this and how to implement this in my application. There is a solution with the OROC-field but I don't know how to implement.
This is my main-calc-record:
record(calcout, "UPDOWN_" ) {
  field(CALC, "A:= ((D=0)?(A=0?0:(A-B))):((C<(A-B))?(A-B):((A+B)>C?C:(A+B)));A")
  field(INPA, "UPDOWN_.VAL PP")
  field(INPB, "SlewRate.VAL")
  field(INPC, "SETVOLTAGE_ PP")
  field(INPD, POWER")
  field(OUT, "DAC_.A PP")                          # write value out
  field(OOPT, "On Change")
  field(DOPT, "Use CALC")
  field(SCAN, ".1 second")
# set command.bit
record(calcout, "DAC_" ) {
  field(INPA, "UPDOWN_ NPP NMS" )
  field(CALC, "(A | 1024)")
  field(PREC, "2")
  field(OUT, "XXX PP NMS")
2.) I use a voltage divider with a poti in rheostat-mode (1024 steps). Because it's non-linear I have to calculate the respective bits for a value. My record works finde:
record(calc, "LINEAR_" ) {
  field(INPA, "LINEAR_ NPP NMS" )
  field(CALC, "CALCULATION")
  field(PREC, "2")
How can I round off the value? Let's say my calculated value is 375,6 (steps). How can I round the result off to 375 and not 376? I want to round off all result:
Example: 512,8 = 512 (noit 513)
Best regards,
Raul
Re: Variable SCAN Intervall and Roundoff function Andrew Johnson
Re: Variable SCAN Intervall and Roundoff function Benjamin Franksen
Prev: RE: installation of synapps_5_8 in ubuntu Mark Rivers
Next: Re: installation of synapps_5_8 in ubuntu Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: installation of synapps_5_8 in ubuntu Benjamin Franksen
Next: Re: Variable SCAN Intervall and Roundoff function Andrew Johnson
ANJ, 16 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
