I am not sure what the problem is.
You could try:
- Upgrading to latest version of autosave
github.com/epics-modules/autosave
Or go back to EPICS base 3.14.12.5 which is what synApps_5_8 is normally used with.
Sent: Tuesday, August 16, 2016 6:37 AM
To: Mark Rivers
Cc: [email protected]; [email protected]
Subject: RE: installation of synapps_5_8 in ubuntu
Here are the complete output from the autosave directory
avanish@avanish-dell:/opt/epics/synApps_5_8/support/autosave-5-6-1$ make
clean uninstall
make -C ./configure clean
make[1]: Entering directory
'/opt/epics/synApps_5_8/support/autosave-5-6-1/configure'
rm -rf O.linux-x86 O.Common
make[1]: Leaving directory
make -C ./asApp clean
'/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp'
make -C ./src clean
make[2]: Entering directory
'/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp/src'
make[2]: Leaving directory
make -C ./Db clean
'/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp/Db'
make -C ./iocBoot clean
'/opt/epics/synApps_5_8/support/autosave-5-6-1/iocBoot'
make -C ./iocas clean
'/opt/epics/synApps_5_8/support/autosave-5-6-1/iocBoot/iocas'
rm -f cdCommands envPaths dllPath.bat relPaths.sh
rm -rf ./bin/linux-x86
rm -rf ./lib/linux-x86
rm -rf ./dbd ./include ./doc ./html ./templates ./db ./adl ./alh ./cfg
./edl ./lib/perl ./lib/pkgconfig
make -C ./configure install
perl -CSD /opt/epics/base-3.15.3/bin/linux-x86/makeMakefile.pl O.linux-x86
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. \
T_A=linux-x86 install
'/opt/epics/synApps_5_8/support/autosave-5-6-1/configure/O.linux-x86'
perl -CSD /opt/epics/base-3.15.3/bin/linux-x86/convertRelease.pl checkRelease
make -C ./asApp install
make -C ./src install
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory
'/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp/src/O.linux-x86'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX
-Dlinux -O3 -g -Wall -mtune=generic -m32
-D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I../os/Linux
-I../os/default -I.. -I../../../include/compiler/gcc
-I../../../include/os/Linux -I../../../include
-I/opt/epics/base-3.15.3/include/compiler/gcc
-I/opt/epics/base-3.15.3/include/os/Linux -I/opt/epics/base-3.15.3/include
-MM -MF osdNfs.d ../os/Linux/osdNfs.c
-MM -MF verify.d ../verify.c
-MM -MF configMenuSub.d ../configMenuSub.c
-MM -MF fGetDateStr.d ../fGetDateStr.c
-MM -MF initHooks.d ../initHooks.c
-MM -MF save_restore.d ../save_restore.c
-MM -MF dbrestore.d ../dbrestore.c
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX
-D_FILE_OFFSET_BITS=64 -I. -I../O.Common -I. -I. -I../os/Linux
-MM -MF asMain.d ../asMain.cpp
Expanding dbd file ../asInclude.dbd
perl -CSD /opt/epics/base-3.15.3/bin/linux-x86/dbdExpand.pl -I. -I..
-I../O.Common -I../../../dbd -I/opt/epics/base-3.15.3/dbd -o as.dbd
../asInclude.dbd
perl -CSD
/opt/epics/base-3.15.3/bin/linux-x86/registerRecordDeviceDriver.pl -I.
-I.. -I../O.Common -I../../../dbd -I/opt/epics/base-3.15.3/dbd -o
as_registerRecordDeviceDriver.cpp ../O.Common/as.dbd
-MM -MF as_registerRecordDeviceDriver.d
-MM -MF asVerify.d ../asVerify.c
Installing created dbd file ../../../dbd/as.dbd
mkdir ../../../dbd
Installing dbd file ../../../dbd/asSupport.dbd
Installing OS dependent include file ../../../include/os/Linux/osdNfs.h
mkdir ../../../include
mkdir ../../../include/os
mkdir ../../../include/os/Linux
-c ../dbrestore.c
../dbrestore.c:1597:13: warning: ‘myDbLoadRecordsHook’ defined but not
used [-Wunused-function]
static void myDbLoadRecordsHook(const char* fname, const char* macro) {
../dbrestore.c: In function ‘reboot_restore’:
../dbrestore.c:888:2: warning: ignoring return value of ‘fgets’, declared
with attribute warn_unused_result [-Wunused-result]
(void)fgets(buffer, BUF_SIZE, inp_fd); /* discard header line */
../dbrestore.c: In function ‘checkFile’:
../dbrestore.c:1186:2: warning: ignoring return value of ‘fgets’, declared
fgets(tmpstr, 29, inp_fd);
../dbrestore.c:1210:2: warning: ignoring return value of ‘fgets’, declared
fgets(tmpstr, 6, inp_fd);
../dbrestore.c:1220:2: warning: ignoring return value of ‘fgets’, declared
fgets(tmpstr, 7, inp_fd);
-c ../save_restore.c
../save_restore.c: In function ‘connect_list’:
../save_restore.c:1333:16: warning: format not a string literal and no
format arguments [-Wformat-security]
errlogPrintf(SR_recentlyStr);
../save_restore.c: In function ‘do_manual_restore’:
../save_restore.c:3128:3: warning: ignoring return value of ‘fgets’,
declared with attribute warn_unused_result [-Wunused-result]
../save_restore.c:3186:39: warning: ignoring return value of ‘fgets’,
while (bp[strlen(bp)-1] != '\n') fgets(buffer, BUF_SIZE, inp_fd);
-c ../initHooks.c
In file included from ../initHooks.c:40:0:
../save_restore.h:42:13: warning: ‘SR_STATUS_STR’ defined but not used
[-Wunused-variable]
static char SR_STATUS_STR[5][10] =
-c ../fGetDateStr.c
-c ../configMenuSub.c
-c ../verify.c
In file included from ../verify.c:17:0:
[-Wunused-variable]
../verify.c: In function ‘do_asVerify’:
../verify.c:69:2: warning: ignoring return value of ‘fgets’, declared with
fgets(s, 6, fp);
../verify.c:73:3: warning: ignoring return value of ‘fgets’, declared with
fgets(s, 7, fp);
../verify.c:307:39: warning: ignoring return value of ‘fgets’, declared
while (bp[strlen(bp)-1] != '\n') fgets(s, BUF_SIZE, fp);
-c ../os/Linux/osdNfs.c
/usr/bin/ar -rc libautosave.a dbrestore.o save_restore.o
initHooks.o fGetDateStr.o configMenuSub.o verify.o osdNfs.o
/usr/bin/ranlib libautosave.a
/usr/bin/g++ -o libautosave.so -shared -fPIC -Wl,-hlibautosave.so
-L/opt/epics/base-3.15.3/lib/linux-x86
-Wl,-rpath,/opt/epics/base-3.15.3/lib/linux-x86 -rdynamic -m32
dbrestore.o save_restore.o initHooks.o fGetDateStr.o
configMenuSub.o verify.o osdNfs.o -ldbRecStd -ldbCore -lca -lCom
-lpthread -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libautosave.so
mkdir ../../../lib/linux-x86
Installing library ../../../lib/linux-x86/libautosave.a
-c ../asVerify.c
In file included from ../asVerify.c:15:0:
[-Wunused-variable]
/usr/bin/g++ -o asVerify -L/opt/epics/base-3.15.3/lib/linux-x86
asVerify.o verify.o -lca -lCom
asVerify.o: In function `main':
/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp/src/O.linux-x86/../asVerify.c:85:
warning: the use of `tmpnam' is dangerous, better use `mkstemp'
-c as_registerRecordDeviceDriver.cpp
as_registerRecordDeviceDriver.cpp:279:12: warning: ‘done’ defined but not
used [-Wunused-variable]
static int done = Registration();
-c ../asMain.cpp
/usr/bin/g++ -o asApp
-L/opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86
-Wl,-rpath,/opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86
as_registerRecordDeviceDriver.o asMain.o -lautosave -ldbRecStd
-ldbCore -lca -lCom
/opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86/libautosave.so:
undefined reference to `_dl_sysinfo'
collect2: error: ld returned 1 exit status
/opt/epics/base-3.15.3/configure/RULES_BUILD:192: recipe for target
'asApp' failed
make[3]: *** [asApp] Error 1
make[3]: Leaving directory
/opt/epics/base-3.15.3/configure/RULES_ARCHS:61: recipe for target
'install.linux-x86' failed
make[2]: *** [install.linux-x86] Error 2
/opt/epics/base-3.15.3/configure/RULES_DIRS:88: recipe for target
'src.install' failed
make[1]: *** [src.install] Error 2
'asApp.install' failed
make: *** [asApp.install] Error 2
Thank you
> ---------------------------- Original Message ----------------------------
> From: "Mark Rivers" <[email protected]>
> Date: Tue, August 16, 2016 4:47 pm
> To: "[email protected]" <[email protected]>
> You should send the complete output when you build in the autosave
> directory
> make clean uninstall
> make
> Mar
> From: [email protected] [[email protected]] on
> behalf of [email protected] [[email protected]]
> Sent: Tuesday, August 16, 2016 6:11 AM
> To: [email protected]
> Subject: installation of synapps_5_8 in ubuntu
> Hi,
> I have copied synapps_5_8 under '/opt/epics'.
> epics-base is already build under /opt/epics/base-3.15.3
> msi is under /opt/epics/extensions/src/msi1.7
> When I am trying to build synapps with areaDetector by using 'make'
> command
> I am getting following errors.
> undefined reference to `__syscall_error'
> I am new to linux and could not get any suggestions from google.
> Please help me
> Thank you.
- installation of synapps_5_8 in ubuntu avanish
- RE: installation of synapps_5_8 in ubuntu Mark Rivers
- RE: installation of synapps_5_8 in ubuntu avanish
Variable SCAN Intervall and Roundoff function info22
<2016>
2025
2026
Re: installation of synapps_5_8 in ubuntu Benjamin Franksen
<2016>
2025
2026
