1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re:
To: Paramveer Jain <[email protected]>, EPICS tech-talk <[email protected]>
Date: Fri, 19 Aug 2016 11:20:01 -0500
On 08/19/2016 12:25 AM, Paramveer Jain wrote:
> thanx for your suggestion
You're welcome. Please keep these conversations on tech-talk though,
that way other people can help to answer your questions too.
>  I Am trying to install MEDM in linux 6.7
>     following is the current problem which I am unable to resolve when i
>     m installing it
> usr/include -I/usr/include/X11   ../xgif.c
> /usr/bin/g++ -o medm  -L/opt/epics/base-3.14.12.3/lib/linux-x86_64
> -L/opt/epics/extensions/lib/linux-x86_64 -L/usr/lib -L/usr/lib64
> -Wl,-rpath,/opt/epics/base-3.14.12.3/lib/linux-x86_64
> -Wl,-rpath,/opt/epics/extensions/lib/linux-x86_64 -Wl,-rpath,/usr/lib
> -Wl,-rpath,/usr/lib64       -m64                medmCartesianPlot.o
> medmSciPlot.o SciPlot.o medmCA.o actions.o bubbleHelp.o callbacks.o
> browserHelp.o channelPalette.o colorPalette.o dialogs.o display.o
> eventHandlers.o help.o medm.o medmArc.o medmBar.o medmByte.o
> medmChoiceButtons.o medmCommon.o medmComposite.o medmControl.o
> medmDisplay.o medmImage.o medmIndicator.o medmMenu.o medmMessageButton.o
> medmMeter.o medmMonitor.o medmOval.o medmPixmap.o medmPolygon.o
> medmPolyline.o medmRectangle.o medmRelatedDisplay.o medmShellCommand.o
> medmStripChart.o medmText.o medmTextEntry.o medmTextUpdate.o
> medmValuator.o medmWheelSwitch.o medmWidget.o objectPalette.o
> productDescriptionShell.o resourcePalette.o updateMonitors.o
> updateTask.o utils.o xgif.o   -lANLwidgets -lPrintUtils -lca -lCom -lXm
> -lXt -lXp -lXmu -lX11 -lXext   -lpthread   -lreadline -lm -lrt -ldl -lgcc
> /usr/bin/ld: crt1.o: No such file: No such file or directory
> collect2: ld returned 1 exit status
> make[2]: *** [medm] Error 1
> make[2]: Leaving directory `/opt/epics/extensions/src/medm/medm/O.linux-x86_64'
The crt.o file is normally found in the glibc-devel package, but I'm
surprised you managed to get this far without having that package
installed. The only way I can think that could happen is if you have
installed the 32-bit (i686) RPM, but you are building a 64-bit (x86_64)
version of medm. Make sure that the RPMs you have installed are for
x86_64 and not just for i686 — my system has both installed, e.g.
tux% rpm -q glibc-devel
glibc-devel-2.12-1.192.el6.i686
glibc-devel-2.12-1.192.el6.x86_64
- Andrew
[no subject] Paramveer Jain
Re: Henrique Almeida
Re: Michael Westfall
Re: Andrew Johnson
RE: Re: Mark Rivers
Re: Re: Henrique Almeida
Re: Andrew Johnson
Prev: Re: MEDM Andrew Johnson
Next: device support for Oxigraf oxygen monitor Sinclair, John William
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Andrew Johnson
Next: problem in installing MEDM Paramveer Jain
ANJ, 19 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
