Subject: |
Re: A Problem while Installing calc in synApps_5_5 |
Ralph Lange <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Wed, 24 Aug 2016 09:44:54 +0200 |
On 24/08/2016 06:41, Mooney, Tim M. wrote:
synApps_5_8 is intended to build with
either 3.14 or 3.15. (I would recommend 3.14.12.5, or 3.15.3.)
I've been regarding 3.16.0 as a development version - an early
look - that is mostly intended to give EPICS application
developers a target to shoot at. I haven't actually tried in
earnest to hit that target yet.
Tim is right. As I stated recently on this forum: EPICS Base
versions with a zero in the update counter (e.g. 3.15.0, 3.16.0.x)
are considered by the developers as "not for productional use",
since they have not had the appropriate amount of testing, and other
packages (modules, extensions, applications) have not been compiled
and tested against them.
However, the development versions of Base do provide an opportunity
for maintainers of other modules to compile against and test, so
that remaining bugs in Base can be found and fixed before the first
"real" version is released, and the new release series gets
supported quickly.
The synApps bundle is a special case, because - as a bundle - it
requires all its packages support a new base release series before
it can bundle them.
As for the original question:
Please use the 3.15 "current" release series of Base that is
supported by synApps.
Cheers,
~Ralph
- A Problem while Installing calc in synApps_5_5 정필규
- RE: A Problem while Installing calc in synApps_5_5 Mooney, Tim M.
RE: tpmac distribution ulrik.pedersen
Re: EPICS and TIA Portal communication Nick Levchenko
<2016>
2025
2026
[no subject] Paramveer Jain
<2016>
2025
2026
ANJ, 24 Aug 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
