1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ipmiComm 3.0.2
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 30 Aug 2016 15:19:18 +0200
I'm trying out ipmiComm 3.0.2 and I'm getting these messages at IOC startup. Any ideas what is wrong? FYI, NAT MCH console shows data as expected. Also freeipmi tools can fetch sensor data.
I created a 6 slot crate out of 12 slot DB files.
# IPMI stuff using vendor 3.0.2
epicsEnvSet("ASYNPORT", "CRATE")
epicsEnvSet("PREFIX",   "IPMI")
epicsEnvSet("MCH_LINK", "192.168.1.41:623 udp")
drvAsynIPPortConfigure("CRATE", "192.168.1.41:623 udp", 0, 0, 0)
mchInit("CRATE")
CRATE Connecting...
Identified CRATE to be N.A.T. IPMI version 1.5
#dbLoadRecords("shelf.db", "dev=$(PREFIX), link=$(ASYNPORT)")
dbLoadRecords("shelf_microtca_6slot.db", "dev=IPMI, link=CRATE, location=")
iocInit
Starting iocInit
## EPICS R3.14.12.5-2015-08 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Oct  9 2015
No device found at specified address PV: IPMI:AMC1:EPWR Failed to locate data structure
No device found at specified address PV: IPMI:AMC1:EPWRDES Failed to locate data structure
No device found at specified address PV: IPMI:AMC1:I1 Failed to locate data structure
No device found at specified address PV: IPMI:AMC1:I10 Failed to locate data structure
No device found at specified address PV: IPMI:AMC1:I2 Failed to locate data structure
No device found at specified address PV: IPMI:AMC1:I3 Failed to locate data structure
No device found at specified address PV: IPMI:AMC1:I4 Failed to locate data structure
[many many lines more]
Hinko
Prev: RE: HOW to start working with EPICS Jemian, Pete R.
Next: PyEpics timeout behavior Guyotte, Greg S.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
